Headlight adjustment on active headlight system
Old Dec 14, 2014 | 07:11 AM
jagtoes's Avatar
jagtoes
Default Headlight adjustment on active headlight system
I can't seem to find in search if there is a way to adjust the up/down aiming of the headlights. I know for the standard headlight system you need to push back the rubber fender gasket to access the hole to adjust the up/down but with active headlights I can't find/feel the adjustment with a long Philips head screwdriver. I assume there is a way to adjust the whole light assembly as I realize that the active system can level itself based on weight in the car. Has anyone done this and if so what is the trick.
Old Dec 14, 2014 | 08:27 AM
mutineer's Avatar
mutineer
Just bought an es350 and I can't find it either
If I figure it out ill post up a pic
Old Dec 14, 2014 | 08:53 AM
nevernu's Avatar
nevernu
this may help
File Type: pdf
Old Dec 14, 2014 | 10:58 AM
jagtoes's Avatar
jagtoes
Originally Posted by nevernu
this may help
Thanks for the pdf file. I will assume that the 2007 is the same as the 2010 and will maybe take some time this week to pull the plastic engine covers to see where these adjusters are located. Even though it mentions to adjust both low and high the same amount I don't have an issue with the high beams. I don't like the driver side low beam being cut off to shortly so I'll just adjust to get maybe another 10'. This should not be a concern with on coming cars but give me a little better visibility. Just a slight tweak.
gearheader
CT 200h Model (2011-2017)
Jun 19, 2018 12:50 PM
w5cdt
Jun 15, 2018 08:44 AM
Vibes63
Sep 9, 2013 09:55 PM
Jubane
RX - 1st Gen (1999-2003)
Nov 5, 2005 02:45 PM
Invisibleman
Apr 16, 2003 12:08 PM
