driver turn signal replacement
Old Nov 4, 2014 | 01:43 PM
robertog11's Avatar
robertog11
Default driver turn signal replacement
I just spent a couple of hours trying to figure out how to reach the left front bulb on my es 300, yr 2000 removing battery, air cleaner assembly. Does anyone have any idea how to reach it? Seems like there ought to be an easier way. thank you. your help will be appreciated.
Old Nov 4, 2014 | 03:10 PM
lostape45's Avatar
lostape45
First remove the black plastic shield above the headlights that's held on by those nasty black clips. Then you should see one screw holding in the turn signal housing.
Hopefully that helps you out.
Old Nov 5, 2014 | 11:24 AM
robertog11's Avatar
robertog11
Thank you. I started to do just that but when one of plastic holder clips broke I stopped. i have a tool to remove door panels and i will try that. thank you for the pictures. very helpful.
Old Nov 6, 2014 | 04:56 PM
drkandre's Avatar
drkandre
When you undo the screw, the corner light pulls straight out towards the front of the car. Don't pull out towards the side of the car. I can supply pictures if necessary
Old Nov 10, 2014 | 02:26 PM
robertog11's Avatar
robertog11
Thanks again. I'm glad you mentioned about pulling light straight out. I would have tried to pulled it sideways. thank you.
Fit1too
Sep 6, 2018 08:02 PM
drseth
Jul 26, 2018 10:27 AM
bluesky
Jan 16, 2010 11:27 AM
99LexusES3
Feb 12, 2005 05:54 AM
ebandaz
Lighting
Feb 19, 2004 02:08 PM
