black insert on ES center console
Old Jul 27, 2014 | 05:48 PM
lesz's Avatar
lesz
Default black insert on ES center console
Has anyone gotten any minor scratches on the black insert in the center console of the ES and found a method/technique for safely removing them?
I picked up a small and very shallow scratch on mine. While I'm confident that I could use a mild polish to remove the scratch, I have no idea how deep the gloss finish is on the material, and I'm afraid that, even if I removed the scratch, I'd be left with a dull spot in the area that I worked on?
While the scratch is small and minor and while it is only noticeable if you are looking for it and the light is hitting it just right, I tend to let things like that drive me crazy, and, so far, the best solution I've found is to place a fingerprint smudge over the scratch, and the fingerprint covers it quite nicely.
Old Jul 27, 2014 | 06:05 PM
bc6152's Avatar
bc6152
I could see that coming when I bought the car. I didn't get any scratches, but I did get smudges that drove ME nuts. Constantly using a microfiber cloth to clean it. I finally gave up and bought a wood grain kit for the entire console. No more fear of scratches or smudges. Les, I think that if you try to polish it out you'll make it worse, create a dull spot.
Old Jul 27, 2014 | 06:31 PM
Canesguy's Avatar
Canesguy
I'll stick with a microfiber cloth and mild cleaner like this:
http://www.griotsgarage.com/product/...ortby=ourPicks
Old Jul 28, 2014 | 07:31 AM
bootman's Avatar
bootman
Got any pics or link of the kit used?
Old Jul 28, 2014 | 08:29 AM
bc6152's Avatar
bc6152
I hope I did this correctly. Check out this link:
https://www.clublexus.com/forums/es3...the-350-a.html
Old Jul 28, 2014 | 08:40 AM
Arty101's Avatar
Arty101
Bob- Your link worked well and your kit still looks good. Too bad no bamboo finish for the 300h.
Old Jul 28, 2014 | 10:30 AM
bc6152's Avatar
bc6152
The supplier stated that there would be a bamboo kit for the 300 - many months ago - but maybe not enough demand for it. Thanks Art.
Old Jul 28, 2014 | 03:18 PM
Arty101's Avatar
Arty101
Bob- I think there are a lot more ES350 sold than ES300h, and therefore less interest in the bamboo kit .
Old Aug 8, 2014 | 01:15 PM
ALIGN's Avatar
ALIGN
The kit looks nice but it seems like they over do it (steering, clock and radio)? Once the adhesive starts to peel off that would really look bad.
The door window switch looks good. But on the radio, it look so obvious that it is a sticker.
Old Aug 8, 2014 | 01:48 PM
lamikela1's Avatar
lamikela1
While I do agree that the stick on applique's are not like the real thing there are a couple of advantages. One is that you can place a cell phone, keys, or anything with a smooth surface on them and it will not move while you are driving. Smooth surfaces tend to stick to it so it holds them firmly. And it's obvious that it cost less for this option. Even so I would hesitate to use any of this on an upscale vehicle.
on the peeling that is not a problem if you take the time to install it properly. I have a carbon fiber one on my Tacoma and it's been there for 9 years now with no issues. Generally you get a adhesion promoter that needs to be wiped on the surface first and then you can apply the applique. I had one section that I did not line up properly when I installed it and you would be surprised how difficult it was to remove. I destroyed it and had to order a new piece. Needless to say I was very careful when I re-installed it.
To each his own but if you can find a nice looking kit that suits your taste then go for it as it will last the lifetime of the vehicle.
Old Aug 8, 2014 | 02:11 PM
bc6152's Avatar
bc6152
This is why they make chocolate and vanilla...
As far as adhesion, it's been on over a year and no issues. I actually did follow the maker's directions and it is on very securely. It's probably 120 F. inside the car as I write this, everything's on tight...Looks great IMO...
Old Aug 8, 2014 | 02:36 PM
Arty101's Avatar
Arty101
Personally, I like strawberry. My friend had it installed in his SC, and it held up without an issue. It looked so custom, I was wondering if it came equipped that way. Nicer than the standard black, IMHO.
Old Aug 8, 2014 | 03:10 PM
LexBob2's Avatar
LexBob2
I agree. I like the "less is more" approach, but it's good to have the option for kits like these.
Old Sep 24, 2014 | 03:54 PM
grabilsm's Avatar
grabilsm
Have you considered doing a vinyl wrap? I did one on my BMW with oem results. I was going to try the same on this car if I can figure out how to take apart the console
3000psi
12
Oct 1, 2023 06:41 AM
sam430
Jun 11, 2013 11:39 AM
jlgaustin
Oct 18, 2009 07:21 PM
Erukian
Apr 9, 2008 04:13 PM
naga11
Automotive Care & Detailing
Sep 25, 2007 10:04 AM
