Replacing headlamp units-help please
Old Jul 2, 2014 | 07:04 PM
brucelee1's Avatar
brucelee1
Default Replacing headlamp units-help please
Hi guys.
I have a headlamp that is gone, moisture inside.
I bought two new HL from Ebay and want to install. My understanding is that the front bumper cover must come off but I cannot find instructions for this job.
Any help would be appreciated.
Thanks
BL
Old Jul 2, 2014 | 07:32 PM
lostape45's Avatar
lostape45
You need not remove the whole front bumper.
Basically what you have to do is remove the top black plastic paneling overtop of the front of the engine compartment by removing the plastic push pins. From there you will have to remove the side marker lights (these come out by one phillips screw attached at the top). Once you get the side markers off, you will see two bolts with nuts on them protruding from side of the headlight assembly, remove those, then there will be one bolt on top of the headlight assembly, remove those 3 and wiggle it out moving toward the center of the car and they should come right out.
Old Jul 2, 2014 | 09:37 PM
01LEXPL's Avatar
01LEXPL
3ES, its about 10 minutes of work.
4ES, front end does have to come off....
Prinny
Jan 23, 2017 11:42 AM
nicks88
Mar 24, 2014 02:48 PM
aljodoro
GX - 1st Gen (2003-2009)
Jun 9, 2009 08:28 AM
AUbeast86
Jan 10, 2008 07:11 PM
