Es 300 cel (bogging down)
Old May 2, 2014 | 06:07 PM
dpmh2227's Avatar
dpmh2227
Default Es 300 cel (bogging down)
My 2000 ES 300 starts and drives good for about 10 mins then it will bogg down like its out of gas lose power for about 3 seconds then good again for 14 seconds then repeats over and over
i replaced VVT Bank 1 didnt help my codes are P0300,P1354(REPEATING),C1201 Bank 1
anyone know what it could be THANKS! DAVE
Old May 2, 2014 | 06:17 PM
310V6's Avatar
310V6
Maybe dirty IACV?
Old May 2, 2014 | 06:18 PM
dpmh2227's Avatar
dpmh2227
Was thinking of replacing fuel filter and or o2 sensor but didnt get code for o2 sensor being bad
Old May 2, 2014 | 06:37 PM
310V6's Avatar
310V6
Fuel filter can change attitude
Old May 2, 2014 | 06:40 PM
dpmh2227's Avatar
dpmh2227
Thanks a lot 310V6 I will try to clean it first thing,will post the results
Old May 2, 2014 | 06:47 PM
310V6's Avatar
310V6
FYI when you remove the IACV, There is a gasket that when removed should be replaced. Especially if the valve had never been removed, it gets flat. It's like$4 at a local auto store.
Old May 2, 2014 | 06:52 PM
310V6's Avatar
310V6
Do you have any major valve cover leaks? Or oil leaks at all?
Old May 2, 2014 | 07:08 PM
dpmh2227's Avatar
dpmh2227
ok thx will def get that gasket
I noticed that the hose going into valve cover was cracked but no oil leaks
Old May 9, 2014 | 01:52 AM
dpmh2227's Avatar
dpmh2227
ok cleaned iacv replaced gasket started ca up idol was good
went for drive was great until about 10 minutes in started same thing
as before.felt like i turned off car for 3 seconds then ran for about 12 seconds
and repeated.could this be electrical?or Catalytic converter?
Old May 9, 2014 | 01:53 AM
dpmh2227's Avatar
dpmh2227
Oh and did notice a little oil leak
ovoxolexus
36
Mar 5, 2022 01:29 PM
LexLthr911
19
Apr 26, 2021 08:16 AM
ArmyofOne
20
Mar 19, 2020 02:34 AM
bucksh00t
Apr 21, 2015 04:23 PM
BostonSC4
Jun 4, 2010 07:46 AM
