Installing aftermarket amp
Old Apr 10, 2014 | 06:26 PM
Rickyram56's Avatar
Rickyram56
Default Installing aftermarket amp
Hi,
I've read on that people have successfully installed aftermarket amps with this car. I have installed many systems before but never on a new car. I looked at the firewall and I prefer not to drill through it. Is if possible to feed the wire through an existing hole that I'm not seeing right now? What's the best way to rub the wire? Also, will install an aftermarket amp/sub void my warranty?
Thanks!
Old Apr 11, 2014 | 04:22 PM
ElliotB's Avatar
ElliotB
Yes, it will void the warranty. I was prepared to have my local Lexus dealer upgrade the audio system which they assured me would not void the warranty but was satisfied with the amplifier 'fix' with the ML system. Do you have the standard system or the ML? Either way, you should discuss your concerns with your dealer.
AshyAnklez
IS F (2008-2014)
Jan 3, 2015 09:30 AM
305Busa
May 6, 2013 07:30 PM
nuonasugen
Dec 12, 2009 10:42 AM
joeker
Apr 20, 2009 09:52 AM
lexluv0277
IS - 1st Gen (2001-2005)
Aug 12, 2004 06:45 PM
