E-Shifter issue on 4th and D(drive)
Old Mar 12, 2014 | 02:46 PM
phongminh's Avatar
phongminh
Default E-Shifter issue on 4th and D(drive)
I have 2002 Lexus ES300.
My car is driving fined with (D)DRIVE, but once I shift the gear to
(4) and shift back to (D)Drive the shifter shift didn't returned back to (D)DRIVE; the rpm is at 4000 on (4) gear on 35mph. I have to put the car in park and turn off the engine and the car work normal on (D) drvie. Anybody have this problem before?
The car have 227k
Thanks
Attached Thumbnails E-Shifter issue on 4th and D(drive)-eshift-2002-es300.jpg
Old Mar 12, 2014 | 03:53 PM
hzt30's Avatar
hzt30
What you are saying is the car comes out of overdrive but does not go back into overdrive. This is done electronically. I take it that the no. 4 light in the dash remains lit? There most likely is a switch under the shift console that needs to be checked for proper operation.
Old Mar 12, 2014 | 07:06 PM
phongminh's Avatar
phongminh
Yes that is overdrive. Do you have the picture of the switch under the shift console?
Old Mar 19, 2014 | 03:05 PM
phongminh's Avatar
phongminh
I found out the problem. The white clip inside the shift is broken. Everytime it on 4 and the white clip didn't returned. What is part number on the picture??
Attached Thumbnails E-Shifter issue on 4th and D(drive)-es300-clip.jpg   E-Shifter issue on 4th and D(drive)-es300-clip1.jpg
Old Mar 19, 2014 | 04:43 PM
hzt30's Avatar
hzt30
Check with a Lexus Dealer as that looks like it would be a Dealer only item. Maybe you could find one in a salvage yard.
Old Jun 20, 2022 | 03:15 PM
StannMan's Avatar
StannMan
7th Gear
Default Cheap and easy fix!
I could not find the broken piece of the switch so I improvised. I have some leftover water tubing from an ice maker install. I cut a 3/4 inch piece, flattened out one end with a pair of pliers then slid it on in place of the missing piece. I shoved it on temporarily to see how long it stays (and works). If it does I’ll glue it in place. It’s 92 degrees today but that hasn’t made it too flexible. I went back and forth between D and 4 and it worked every time. With $6 gas I need that overdrive selection!
Kind of hard to see.
Zoomed 2X
Hard to see.
nodeal
Dec 21, 2018 03:40 PM
SharkTales
Jul 26, 2012 11:43 AM
ilv1004s
Feb 2, 2010 04:26 PM
Blue4reF1
Aug 28, 2009 06:30 AM
