Tripometer
Old Mar 11, 2014 | 10:33 AM
4x4tx's Avatar
4x4tx
Default Tripometer
Ok where is the trip odometer on the 14 es350?
Old Mar 11, 2014 | 10:42 AM
lesz's Avatar
lesz
Just press the display/info button on the steering wheel and the trip odometer is one of the information items that it will cycle through and that will appear in the information display in the middle of the instrument panel.
Old Mar 11, 2014 | 10:51 AM
jonmanch's Avatar
jonmanch
Isn't it on the panel behind the left side of the steering wheel? It is Trip A and Trip B and the Odometer.
Old Mar 11, 2014 | 10:54 AM
LexBob2's Avatar
LexBob2
This is good information to look up in the owners manual. When thumbing through it, you also come across other features and how to use them. Even find some hidden gems now and then.
Old Mar 11, 2014 | 10:59 AM
lesz's Avatar
lesz
You are right. I was thinking of the mpg after refueling information, and I was confused because, when refueling, I always check the after refueling information and re-set the trip odometer at the same time.
Old Mar 11, 2014 | 11:13 AM
4x4tx's Avatar
4x4tx
Panel behind the left side of the steering wheel? like where the fog light button and fuel door release is at? The car is my wifes so don't get to spend too much time behind the wheel
Old Mar 11, 2014 | 11:19 AM
alpinefun's Avatar
alpinefun
Let say if I never reset trip B in order to know average gas mileage for a car life. Where can I read that mpg for a trip B?
Old Mar 11, 2014 | 12:42 PM
jonmanch's Avatar
jonmanch
Higher up and a little to the right. It is to the left of the steering column; not on the left stalk.
Old Mar 24, 2014 | 01:00 PM
mcomer's Avatar
mcomer
reposted from "setting trip odometer"...
Quick review of the mileage tools we have, trip A & B are distance only, hard keys on the lower left side.
Right steering wheel spoke toggle, "After Refueling" resets itself when...you refuel. (Doesn't have to be a fill-up)
"Average MPG" has the most flexibility. If left unreset it will accumulate data for 10k miles. Everytime you do reset it check out the Nav screen display Menu/Fuel Economy/Past Record (History on Non-Nav). Note that the date at bottom of the graph now has todays date. Want to reset every Monday morning and compare cold weeks to warm? Want to reset before a different driving routine? Outbound and inbound legs of a commute?
Notice also that while the DIC (by the speedo) has elapsed time and average speed that remain until reset, the
Trip Information (both Nav & non) starts out fresh each trip. Range matches the DIC display of course.
docden
RC - 1st Gen (2015-present)
Oct 10, 2018 09:23 AM
57Strat777
Feb 16, 2017 11:05 AM
Tomcio78
Nov 21, 2012 01:08 PM
steve1117
Apr 1, 2012 05:24 PM
Peter53
Oct 18, 2007 08:43 PM
