help with rust in engine
Old Oct 16, 2013 | 12:27 PM
albertldee's Avatar
albertldee
Default help with rust in engine
i park my car sometime for about 5 to 8 month in a year in the grarage drive way i try to was the snow off before leaving it, i do not have a car cover on it now i notice a whole bunch of rust in the engin how can i get rid of those rust i think i may need to change those hose clip how can i stop the rust from gtting wrose what can i put on it
Old Oct 16, 2013 | 12:53 PM
PFB's Avatar
PFB
Spray some WD-40 on the rusted metal parts (Not on rubber) and use a toothbrush to rub it in, and to scrub the rust away. Most of that rust should come out.
Once clean, Canadian Tires sells several spray on products specifically designed that you can than use to spray those areas. This should prevent/delay the rust from coming back.
Alternatively, you can cover those areas with a LIGHT coating of engine oil, but the Canadian Tires spray is easier to use, and can reach into places that you can't.
You should also think about having your whole car rustproofed. Its never too late.
A car that is kept outside in the winter, will form much less rust than a car that's kept in a warm garage, so I don't know why your car has formed those rust areas.
Phil
Old Oct 16, 2013 | 09:01 PM
Dawa's Avatar
Dawa
all the zinc plating has been eaten off your parts
but yeah, do what PFB said
motor oil/similar can be used to pretty much put on any bare metal and prevent it from corroding.
some of those bare metal hot/rat rod guys use it on their vehicles, machinists use it after theyre done machining engines/parts, and you can apply a THIN coat to non chromed/finished tools as well
Old Oct 17, 2013 | 09:20 AM
albertldee's Avatar
albertldee
thanks man its the first car i own with rust like that i left my car park in florida for up to a year no rust
i got this rust check spray at canada tire i'm going to spray it on after washing it
Old Oct 17, 2013 | 11:40 AM
imherenow's Avatar
imherenow
As soon as you bring it to canada should get the car Rust Check
Old Oct 18, 2013 | 03:12 PM
brucelee1's Avatar
brucelee1
You may also need a little wire brush if the toothbrush won't do it.
Old Oct 18, 2013 | 03:24 PM
PFB's Avatar
PFB
Post new pictures when you're done
Old Oct 19, 2013 | 06:57 AM
brucelee1's Avatar
brucelee1
I forgot to mention. How about a good clearing of the entire engine bay first? That will reveal other areas that may need attention and help prevent future problems.
Old Oct 20, 2013 | 09:11 AM
skillvsluck's Avatar
skillvsluck
atleaast its just surface rust, could be way worse
Old Oct 20, 2013 | 01:13 PM
Dawa's Avatar
Dawa
oh another method...
take off the part, hit it with abrasive (wire brush, sand paper, etc)
and then just paint it. id suggest at least 2 light coats
that, or you can paint it as is, as well, but it wont be as effective.
bryceis250
Jun 3, 2018 06:49 PM
fleishelja
Feb 14, 2010 02:38 PM
JeffTsai
Dec 29, 2008 01:14 PM
rawfish
Automotive Care & Detailing
Mar 23, 2008 05:56 PM
VIP Style
40
Mar 15, 2007 08:21 PM
