Help! 1997 ES300 Parasitic drain on battery and tracked it down to the ECU-B 10A fuse
Old Feb 26, 2015 | 12:51 AM
  #31
ES300NZ's Avatar
ES300NZ
Originally Posted by Emuller
The 7.5 amp fuse was pulled and left out the last 24 hours. Car battery held it's charge, and motor starts fine, but many features are inoperative. IE locking door w/ fob, door lock switch on door , air conditioning settings, window switches to name a few.
> - this means that I'm almost certainly wrong about the function of that circuit.
> - I shall tell my wife, the unthinkable has happened. I was wrong. The world will end now. :P
The issue is definitely the circuit. My problem now is how to isolate the problem item on that circuit. I ordered a haynes repair manual, so this may cover a in depth repair, or at least an accounting of all the items impacted by the ECU-B. Is there a way to disable each of the users of this circuit?
>- if it was me, I would open up the electrical diagram and follow that.
> - you could track down the plugs and disconnect things one by one.
Old Jun 21, 2020 | 08:55 AM
  #32
cdunca647's Avatar
cdunca647
Default Seat "Set" switch
+1 for the seat set switch root cause for drain via the ecu-b fuse. I was able to get the button loose. Super easy fix. Will probably disable the button completely to avoid recurrence.
Old Sep 8, 2020 | 09:18 AM
  #33
asorowka's Avatar
asorowka
Thumbs up
Glad I came across this thread. I had similar battery drain issue. Replaced 3 batteries over the past year and a half, along with countless trickle charge sessions. Never would I have suspected a stuck Seat Set button being stuck. Just for yuckers, I decided to check if I had the issue. Sure enough, the Set button was stuck in the down position. I used a dental pick to pry it free. So far, so good. After a few days, starts great. Now I just need to track down why my rear lights fault dashboard light is illuminated, although all back lights seem to work.
Old Oct 31, 2024 | 12:18 PM
  #34
GS4001998's Avatar
GS4001998
3rd Gear
Default Fuses
Originally Posted by DGIKULJOT
I found another post that says it is related to the anti theft, door locks, security system.
But lets just wait for others to confirm this
On mine, that fuse is ECU-IG. ECU-B2 is power seats.
Old Dec 23, 2024 | 08:11 PM
  #35
groomerz's Avatar
groomerz
Thx to all 98 es300 80 mA draw dead battery , Seat set switch stuck down , pulled it up and cleaned with brake cleaner and now draw is 10 mA. switch had some green on one of conductor just left switch button unplugged as my daughter doesnt use the seat memory.
Catalina45
Sep 3, 2019 07:43 PM
LexXxtacy
Nov 26, 2012 05:02 AM
HowieSJH
Aug 22, 2007 08:15 AM
SirSam
Jan 13, 2006 07:45 PM
Automan
Sep 16, 2003 11:03 PM
