No Power Steering
Old Jul 26, 2013 | 07:39 AM
8253MA's Avatar
8253MA
Default No Power Steering
I apologize in advance if this has been answered previously on the forum, I just couldn't seem to find it!
93 ES300
The car developed a wobble at various speeds and the tires were balanced. I replaced the front struts, ball joint, axles, sway bars, and outer tie rods. Wobble went away. However on the test drive after replacing the previously mentioned the power steering quit while I was at a stop light. I made a left turn and the power steering returned to normal.
The following day, after driving approximately 15 miles, the power steering failed again, returned briefly then quit again and has not returned. Power steering reservoir is full and has not lost fluid. The fluid does look original though. No leaks at all underneath of the car. The steering is smooth from full left to full right with no noise, binding, or popping. The fan appears to be operating normally. No squeaking from the belt though it did get a healthy dose of PB Blaster during the maintenance on the suspension. Not sure if the suspension maintenance is related but since it occurred immediately after I figured I should mention it.
Any thoughts, related experiences or advice would be appreciated.
Old Jul 26, 2013 | 09:03 AM
PB Blaster on the belt is not a good thing, clean the pulleys with brake cleaner, replace the belt and go from there.
Old Jul 26, 2013 | 09:53 AM
rlx101's Avatar
rlx101
yes, sounds like the belt is slipping on the lubricant.
Old Jul 26, 2013 | 12:53 PM
8253MA's Avatar
8253MA
Cleaned the pully and put new belts on. No change.
Old Jul 26, 2013 | 02:06 PM
Hayk's Avatar
Hayk
Do you have good tension on the belt? Your pump might be failing, if everything else is fine.
Old Jul 26, 2013 | 07:01 PM
8253MA's Avatar
8253MA
I crawled under the car preparing to start the removal of the PS pump and I noticed the solenoid attached to the pump looked loose. I cleaned it off, checked the connections, gave it a friendly tap and now everything works fine.
Old Jul 26, 2013 | 07:35 PM
Hayk's Avatar
Hayk
Nice work, glad it was a simple fix.
jeffyjeff
Dec 7, 2022 12:40 PM
realsync1
Jul 7, 2018 06:54 PM
Dylroberts
Sep 24, 2015 11:46 AM
SC_Edgar
Jul 31, 2009 12:19 PM
Och
GS - 1st Gen (1993-1997)
Jul 31, 2003 09:23 PM
