2005 ES330 turns over-will not start
My Lexus ES330 has run great. Last nite as I was leaving work i got in to start it. It kept turning over but would not start. To make matters worse, I looked at my key and all my buttons had fallen out. By the way it is a 2005. Any ideas.......
I'm having the same problem on my 2000 es300. During cold start up, it turns over but dies immediately UNLESS i press the throttle then its good. I replaced the fuel filter just to make sure......still having the same problem. Also, when i put the key to the on position i can hear the fuel pump engaging(2-3 second funny sound). So check if your fuel pump is engaging when key is on the ON position.
