AC for 93
My AC doesn't blow cold on 1993 model. On the hood, I see a tag that says R12. I'm sure that's been replaced. So can this be made to work, for reasonable fee?
My other 93 has a sticker on the firewall from 2002, from a AC tech indicating R134A. Was that updated then?
Simply put, if a can of 134A will fit on your fitting it has been modified, otherwise, you might want to use your windows more, as a retrofit can be fairly expensive (especially if a shop does it)
On a related note, it might not be a lack of refrigerant that is preventing your AC from blowing cold. If your compressor never engages then it would never cycle properly. you might want to have a professional look at it to diagnose your actual problem.
There is mother one called Freeze 12, but don't know who caries it in Canada.
Walmart may have something similar as well. Not sure.
I personally have no experience with these products
Phil
You will need to either buy/borrow a special A/C vacuume pump, or alternatively have a shop do it for you.
The vacuume purge will also help determine if you have any leaks in your system. Save you from refilling it, only to have it escape again
The A/C season didn't start yet, so it maybe less expensive to deal with it now.
Phil
Phil
On the cheap side;
Check the condenser in front of the radiator for damage to the fins, and straighten any you find bug smashed. Check the fuse and relay for the AC system. Buy a can of refrigerant with a gauge and see what the pressure on the low side is according to the can.
Any more than that, you should have the pros handle it, but expect to pay well over $1,000 US. Probably closer to $1,500.
If you don't have a set of manifold gauges and at least some basic knowledge of A/C systems then you should bring the car to the experts. You can't start hooking up cans of refrigerant and hope for the best.
The first thing you MUST do is pull a vacuum on the system with a pump designed for the task, then leave it alone for an hour to see if it holds vacuum. If it does, then you can proceed to fill the system properly with refrigerant and oil.
A quick way to tell if the system is charged is to turn on the AC with the car running, look at the end of the compressor clutch past the belt. It should cycle on - off, on - off etc every 15 to thirty seconds. Place your hand on both of the two metal lines going from the condenser to the evaporator. The larger line should be somewhat hot, and the other will be very cold. If one doesn't feel very cold, and the clutch cycles at a fast rate, then you are probably low on refrigerant. Being low on coolant means there is a leak. The leak could be small enough that you can recharge it with a can of refrigerant yourself, but the amount of refrigerant is critical because too much refrigerant will ruin the compressor. Both low pressure and too high a pressure will make for no cold air at the vents. Also air or water is the system will make for no cold air at the vents and anytime the system is opened, the filter / dryer should be replaced for this reason. An AC thermometer is used by placing the tube part into the center vents with AC on high and the door open to check temp which should be roughly 38 - 45 degrees on a functioning system. AC systems should be serviced every few years, not that anyone does it. This includes evacuating the system, replacing the filter dryer, pulling a deep vacuum and recharging the system. AC systems are expensive to repair if anything other than a fuse, or relay is failing.
