Coolant drain and refill for 97-01
Is it possible to replace the coolant drain plug on the bottom of the radiator. When I drained and refilled my coolant the spout continued to leak. I tightened and tried to push it in but still to a small leak. can you help me with this?
Inspect the spout. I believe it's supposed to have a small o-ring on it - you will have to drain the radiator to do that. If there is no obvious cause, a radiator replacement will be required, or you can permanently seal the area with something like JB Weld.
Appreciate the help
if i am replacing the thermostat do i still need to touch the drain plugs on the radiator and engine RR for coolant removal.
Most likely yes, but I don't know how much you will need to remove. You could just let the excess drain through the thermostat opening, so that you don't remove unnecessary amounts of coolant.
I found the drain plug #1 which is very easy, but when I moved to drain #2, I saw three sets of bolts and hole, one hole is with thread, one other hole without the thread. and I tried the 3/8 IO pipe it too big to insert into these holes, I am attaching the photo, and drain #3 is between the two pipe, but don't know I am looking at the right one?
attach is the photos.
thanks everyone can help?
I will be able to find all the rest of Drain Plugs, after emptied coolant on the drain #1 and #2, the rear drain plug is to look between this manifold , there is no coolant, and also after put distilled water, and still nothing come out of it. and I notice the bolt cannot turn much. I am afraid use force, so I just go ahead, processed with the project.
Any idea?
Thanks
Any idea?
Thanks
Hi MrBooby,
Yes, that is it, but I am trying counter clockwise with the bolt, it only moved 2 inch, so I didn't get the old coolant out from that, since I can't wait, sinceI got a lot old coolan out of #1 and #2 drain plugs, I end the project, just curious what cause it? May be the bolt was bad?
Thanks
Thanks
