Problem with 93 ES300
Old Apr 19, 2012 | 01:08 PM
AdexGold's Avatar
AdexGold
Question Problem with 93 ES300
i recently got a 93 ES300, what would make it have this problem,
When you turn it on the speedometer reads 80MPH and 1500RPM, even when it is in park, once it is in gear the gauges go back to normal but it stays in 3rd gear, i thought it might be something wrong with the transmission being as that it stays in 3rd gear when driving, you can drive it perfect if you shift manually, but once changed the transmission it still has the same problem, i believe now it is the computer but dont want to buy that and it not be the problem, what is your suggestion on what the problem could be?
Old May 7, 2012 | 06:29 PM
Mxkmster's Avatar
Mxkmster
I'd check to see that there isnt any corrosion on the ground side of the cluster. Pull trim and the cluster out and check it with a known good custer is a great way to check and see what to do. A trip to the junkyard helps. That way if it isnt the cluster you didnt pay a lot for it. The speed is from the abs rings on the axles so you can check the wiring from there to the ECM. An ECM is easy to get to if you go to the junkyard. You can get both the cluster and ECM and not drop more than 100 dollars for both.
4mula_J87
Jul 18, 2011 11:07 AM
03EStwin
May 16, 2010 11:32 PM
jaborinity
Oct 23, 2008 02:05 PM
omega808
Aug 18, 2008 10:16 AM
Tomee
GS - 1st Gen (1993-1997)
Jan 6, 2008 07:53 PM
