Parking Lights
Old Nov 19, 2011 | 09:55 AM
AlphaOnion's Avatar
AlphaOnion
Arrow Parking Lights
Question: I looked at the diagram for the front turn-signal/parking light, and I'm trying to find which wire leads to the parking light. Based on the diagram I think it's the 2 smaller wires that are white and green. There's only 1 other wire, which is thicker than those 2 and it's green. I assume that is for the turn signal. Am I correct, or can anyone tell me which is the right wire(s)?
Old Nov 19, 2011 | 10:34 PM
Hayk's Avatar
Hayk
That's a pretty technical question, so I doubt you'll get many responses from here. Good luck to you, I just thought I'd post here since I know how it feels when nobody answers to your threads.
Old Nov 19, 2011 | 10:39 PM
Take a look here
Old Nov 20, 2011 | 12:11 AM
AlphaOnion's Avatar
AlphaOnion
No problem guys, I figured it out (kinda). I was asking this so I could wire in my halos, which I did, and they work great. The only problem is that the parking light and turn signal light are the same connector and same bulb. You have to splice the right wires to make sure the halos only replace the parking lights and that the turn signal still works. I did this and the turn signal still worked, but only on the driver's side which was the FIRST one I tried. I did the exact same thing on the passenger's side and made sure the wiring was IDENTICAL, but for some reason the turn signal won't work on the passenger's side. Any ideas why this might be?
dci4life
Jul 17, 2012 06:41 PM
ISCjonny
Feb 1, 2008 10:14 PM
datsetup
Nov 26, 2005 11:43 PM
GSAristo
May 22, 2001 11:22 PM
