97ES stereo remove from deck instruction?
Old Sep 1, 2002 | 10:46 AM
Shinchan's Avatar
Shinchan
Default 97ES stereo remove from deck instruction?
does anyone know how to remove the 97ES300 stereo from the deck? any DIY instruction? Help?
Old Sep 10, 2002 | 02:52 PM
LEXBERG's Avatar
LEXBERG
search on here there's a thread with pics and all on here
Old Sep 11, 2002 | 06:10 AM
NYC ES3's Avatar
NYC ES3
Default Looks harder than it is
pull out top air vents housing ..(air vents and all, grab a firm hold they are clipped in) pull the whole piece out towards you (its all one peice) then under climate control the plastic right above the ash tray ..at the bottom of that plastic peice ,on the underside of it put a very very small screwdriver in the tiny openings and pull towards you... that is held with clips also, one on either side. This will expose the 4 screws. 2 on the top under the air vent houseing and the 2 screws on the bottom under the plastic piece between the ash tray and climate control.....unscrew them (10mm ratchet) and the whole thing comes out climate control also, the radio and climate control ane held together by a bracket that mounts the two of them in the center console.....Hope this helps
Old Sep 11, 2002 | 06:13 AM
NYC ES3's Avatar
NYC ES3
Default Hey Shinchan by the way...
Shinchan the mods you have listed - is that on a 97 ES300??? If so can you let me know where you got them, the strut tower brace and ECU and basically all that....spead the love????? if you can ..thanks
Old Sep 12, 2002 | 09:26 AM
Shinchan's Avatar
Shinchan
The mod that I have in my sig is for my GS4. The reason that I am asking is that my bro has an ES3.
Old Sep 13, 2002 | 02:36 AM
NYC ES3's Avatar
NYC ES3
Default Hope it helped
Hope what I wrote helped your brother.......I went through that same thing about 4 months ago....
GS213
May 23, 2011 02:15 PM
PolishJoe
Mar 11, 2011 12:46 PM
Billh2
Dec 27, 2006 06:01 PM
1st Listen
Dec 1, 2003 05:15 PM
madmadrid
Nov 27, 2002 01:42 PM
