code P0171 (system too lean-bank 1)?
Old Apr 9, 2011 | 01:32 PM
ayroman's Avatar
ayroman
Arrow code P0171 (system too lean-bank 1)?
checked my engine light at Autozone and the codes on my es300 1998 were:
1. P0300, P0301, P0303, P0305 (random cylinder misfire, cylinder misfire 1, 3, and 5).
2. P0171 - "system too lean- bank 1 (cylinder number 1 denotes bank 1)"
I had some recent repairs, which are: tuneup (spark plugs, ignition coil #2, ignition coil wires), oxygen sensor (bank 1 sensor 1).
i have visited several mechanics, none of them have pointed to a particular problem, basically they are trying to change most of the engine. Please share any tips that you have thx.
Old Apr 9, 2011 | 05:49 PM
brandoe91's Avatar
brandoe91
Try changing the coil wires as well.This helped with the misfire for me.
Old Apr 9, 2011 | 07:34 PM
worldforgo's Avatar
worldforgo
I would put money on the fact that the O2 sensor was misinstalled. When you are having multiple misfires and a System to Lean, that usually points to something like an O2 Sensor. Plus 1,3,5 are all Bank One Cylinders.
Old Apr 9, 2011 | 07:53 PM
ayroman's Avatar
ayroman
the codes were in place before the o2 sensor was changed. basically i had all of these ocdes plus the o2 sensor code simultaneously. so i have changed the o2 sensor thinking it would solve all the codes, but it didnt.
Old Apr 10, 2011 | 07:04 AM
worldforgo's Avatar
worldforgo
Well System to Lean means that the O2 sensor is reporting too much oxygen. That means either Your mixture is actually off or there is a sensor that is malfunctioning. I would check the Mass Air Flow sensor, which can cause a System to lean although I am not certain that would cause Misfires. Is the car actually running poorly? With 3 Misfires it would be running like crap, and just barely at all.
Old Apr 10, 2011 | 09:14 PM
angmedic91's Avatar
angmedic91
Ayroman, do you have an aftermarket intake system or K&N filter?
Old Apr 10, 2011 | 11:22 PM
ayroman's Avatar
ayroman
i dont know if i do, and dont even know how to check that.
Old Apr 11, 2011 | 09:20 AM
VicsIS350's Avatar
VicsIS350
Exclamation
You did your spark plugs right? I hope you checked gap even if pre-gapped..in transportation pre-gapped can get out of recommend gap. I had misfires on my Benz which only showed up at higher RPMs which I didn't know at the time it was detonation based from using lower grade fuel then recommended for my car. I bought new pre-gapped plugs and checked them prior to install and most needed to be re-gapped again. So check that they are definitely gapped correctly.
Old Apr 11, 2011 | 03:23 PM
ayroman's Avatar
ayroman
here is an update this this P0171, i have removed the code through the engine checking computer. Drove the car for abput 25 miles, and the check engine light popped up, i immediately drope up to autozone and checked for any codes, and the only code this time was:
P1133 ("air/fuel ratio sensor circuit response malfunction bank 1 sensor 1"),
But keeping in mind that i have changed my bank 1 sensor 1 O2 sensor just last a week ago. some symptoms are :the car hesitates and loses power from time to time.
Old Apr 11, 2011 | 04:10 PM
VicsIS350's Avatar
VicsIS350
Did you check my response above?
Old Apr 11, 2011 | 04:13 PM
VicsIS350's Avatar
VicsIS350
Hesitation or loss of power can be the spark plugs installed with wrong gap
Old Apr 11, 2011 | 04:37 PM
ayroman's Avatar
ayroman
thanks for your input, my spart plugs were changed by an experienced mechanic, at least thats what i think, along with the wires. I am not sure tho
Old Apr 11, 2011 | 04:51 PM
angmedic91's Avatar
angmedic91
The P1133 is a Lexus specific code and it appears related to your air/fuel O2 sensor. Did you have all 3 replaced or just certain ones? And did you use the Denso OEM O2 sensors?
Old Apr 12, 2011 | 12:43 PM
ayroman's Avatar
ayroman
i have only changed the bank 1 sensor 1 oxygen sensor (before ct converter), and yeah i bought it from Denso.
Old Apr 12, 2011 | 05:08 PM
angmedic91's Avatar
angmedic91
Hmmmmmm, ok, well, appears you had the proper one replaced. Here in Calif. we have to use a specific air/fuel O2 sensor, because of the strict Calif. emissions. There are two parts numbers for the O2 sensors, one is for Calif emission vehicles and the other is for non-Calif emissions. Hopefully, you have the right one for that ES300. Otherwise, dont know why your having a CEL for the O2 sensor if you got the proper one replaced. Keep us posted and maybe you might have to take it into a Lexus dealer or find a Lexus mechanic who can diagnosis the issue right away. Good Luck.
