LED bulb replacment chart...
I would like to change all my bulbs to LED's ..
Has anyone done this..
have a link or bulb chart for info..?
Fog light HID replacement as well..
But, more concerned about the DRL, front and rear turn signals.. into LED's
http://www.sylvania.com/ConsumerProd...lacementGuide/
Choose your vehicle from the list and a chart should show up with the bulb numbers.
Fog lights to HID's should be a fairly straightforward install. However, if you want to convert your DRL's to LED, you will lose the functionality of the high beams because LED's will not throw enough light forward. It will only be for looks while your DRL's are on.
Regarding the front/rear turn signals, you should be able to install LED's, but you may need a resistor or the dash might show a light out because of the lower power consumption of the LED's vs. incandescent.
Kumar350
Jan 5, 2015 05:00 AM
mrxthuan
Aug 3, 2009 06:57 PM
