I'm Back with 2 fully functional no-cel, no-odd noise ES300's =)
Old Jun 17, 2010 | 06:25 AM
ES3_Ray's Avatar
ES3_Ray
Default I'm Back with 2 fully functional no-cel, no-odd noise ES300's =)
So if you guys were keeping up with my last thread, My 98 ES was making a horrible noise. Found out it was a cracked flywheel...
replaced it and now the car runs 100% fine. Within that time, my father and i found a replacement car for very cheap because it was making a very odd noise at idle after the motor warmed up and this is how it went after we picked it up:
There was a faulty catalytic converter, which in turn caused excessive back pressure and heat, and caused cylinders 2,4, and 6 (front bank) to wear out the piston rings. Result: Low compression.
Cleaaaannnnnn
Old Jun 17, 2010 | 10:46 AM
ES3_Ray's Avatar
ES3_Ray
worn cylinder walls, aka, source of the low compression, closest cylinder: re-honed...
before....
after!
before...
after!
12
washing up
13
14
15
16
17
18
19
20
21
22
23
24
25
Old Jun 17, 2010 | 12:18 PM
01LEXPL's Avatar
01LEXPL
Yeah, sweet. Glad to hear it worked out.
I hope you are keeping the 2000 for yourself? And maybe actually get a set of rims this time around!
Old Jun 20, 2010 | 09:32 PM
ES3_Ray's Avatar
ES3_Ray
27
Old Jun 20, 2010 | 10:11 PM
renatodato's Avatar
renatodato
Awesome job. Did you use the services of a machine shop at all? Are you a professional mechanic or just a hobbyist? Are those individual ignition coils? ie, distributorless? Just curious.
Old Jun 21, 2010 | 07:23 AM
JamesBond1's Avatar
JamesBond1
Congratulations but with your title "I'm Back with 2 fully functional no-cel, no-odd noise ES300's =)" you make it seem like it's rare to find an ES300 that's fuctional or without it making noises I'm just saying.
GL with the rest of your work!
Old Jun 21, 2010 | 08:22 AM
Slooooooow's Avatar
Slooooooow
Regional Officer - NTL
Wink
What kind of engine do you have there? 2JZ? 3VZ? 1RAY?
Gratz on all the hard work, the positive results, and the 2nd car!
Old Jun 21, 2010 | 08:33 AM
slvrboolet's Avatar
slvrboolet
nice work how much did u get the fubar es for? I always see cars on cl with some kinna problems just wish i was handy enough to buy myself and fix them.
Old Jun 21, 2010 | 07:00 PM
ES3_Ray's Avatar
ES3_Ray
the only service i used the machine shop for was to clean the valves. the ones with bad compression had severe carbon buildup. so i got them bead blasted, $1 each =24 bucks lol
thanks! its on the road now and the 98 is up for sale. i think the main reason i chose that title is because my last thread mentioned the odd noise my 98 made, no harm on the ES's reputation
i grabbed it for 2300, but i had to go there and tow it home so it cost a bit more than that. parts and stuff added up, i dont even know what kind of labor charges i saved myself. it wasnt a fubar'd ES either, it ran, i think i woulda ran the car as is until i did the compression test. just after that, it really got me thinking
Old Jun 21, 2010 | 07:02 PM
ES3_Ray's Avatar
ES3_Ray
Thanks! lol idk what i could call that, something along the lines of 2 legged animal or person, i guess i would call it a 2RS-SE lol
Old Jun 21, 2010 | 07:59 PM
Ariyanna's Avatar
Ariyanna
congrats RAY that is some serious work u did there and how does the car drive now after that rebuild (AKA NEW ENGINE)??
Old Jun 22, 2010 | 09:16 AM
ES3_Ray's Avatar
ES3_Ray
the car drives amazingly well, in relation to my dads 99 with the same motor, it has a noticeable amount more kick to it. it could be a result of me accidentally doing something right by polishing up the intake manifold and heads, but my dad got in the car and said, "Hey, my car doesnt do this" refering to the acceleration. we then proceeded to test the compression. all 6 of my pistons are at 165-170 psi and his have a better seal at 180-185psi. we will have to see how much of a difference my car has when the rings are properly seated...i cannot wait to put it to the floor =)
Old Jun 22, 2010 | 11:18 AM
Maxx941's Avatar
Maxx941
Good hard work payed off. Great Job! what else you got up your sleeve?
Old Jun 23, 2010 | 06:59 PM
ES3_Ray's Avatar
ES3_Ray
my next project falling out of my sleeve (with nothing to do with the car) is actually a central air unit, me and my father are approximately 70% done so as for now, the car is what it is..and i am very happy with that lmao (its so fast )
Old Jun 23, 2010 | 08:58 PM
RXGS's Avatar
RXGS
I like all the work you've done, looks great, but i have a question. Have any of your neighbors, or anyone for the matter ask you why you have 3 of the same car? haha
