Blinking CEL + engine shake / loud click
Old Mar 7, 2010 | 09:55 AM
BoostedE21's Avatar
BoostedE21
Default Blinking CEL + engine shake / loud click
Strange thing -
This morning I was driving along just fine. I pulled into our hotel, and the engine started shaking rhythmically - felt like a misfire. Turned it off, waited about 30 minutes, and tried again. This time, the shaking was worse - especially at low RPM. The CEL started blinking, so I shut it down.
I'm 95% sure it's just a misfire, and I'll have to borrow a code reader to verify - probably a failed coil back or an ignition wire that's come lose. But then again, when I was driving it (still shaky but no CEL at this point), I heard a LOUD clicking noise whenever it was under load. Sounded like an old worn out pushrod engine almost. Not sure what would cause that. Any ideas?
Old Mar 7, 2010 | 10:00 AM
rjheger's Avatar
rjheger
sounds like a misfire to me.. maybe fuel injector goin bod too..
Old Mar 9, 2010 | 06:53 PM
BoostedE21's Avatar
BoostedE21
P0304...Misfire in cylinder 4.
Edit: Just realized, the ES has one coil per cylinder. Cool, that makes things pretty easy.
Old Mar 10, 2010 | 09:23 PM
dcapo's Avatar
dcapo
was it a mild shake or really bad shake like u could feel it
Old Mar 10, 2010 | 09:25 PM
dcapo's Avatar
dcapo
u can also check ur coils by unplugging them from the wire while the car is on, trust me u will know which is good/bad and also pull apart n test against ground point to see spark
Old Mar 10, 2010 | 09:35 PM
BoostedE21's Avatar
BoostedE21
It was a rhythmic shake that increased with RPM. I tested the coil by pulling the coil/plug and letting it arc over on the body to observe a spark. Unplugging them while the car is on was fine too, but if it was a spark plug or fuel issue, unplugging the coil isn't enough within itself to isolate the issue. I solved this problem in another thread.
chenxingha
RX - 1st Gen (1999-2003)
Apr 21, 2018 11:04 AM
Brit50
Sep 4, 2015 11:30 AM
wfu1994
Aug 12, 2010 09:36 AM
LiqrSicc
May 13, 2009 04:05 PM
spike19
Apr 14, 2009 07:57 PM
