1996 Lexus Es300 starting problem
Old Jan 18, 2010 | 12:57 PM
bbb17's Avatar
bbb17
Default 1996 Lexus Es300 starting problem
My fiancee has a es300 and recently she got a flex pipe installd on her car because someone stole her catalytic converter. She got this installed about three days ago. Everything was fine until yesterday when she went toi crank her car and it turned over but then cut off immediately and when she tried to press the gas to keep it on it cut off faster. I asked someone and they said it might be her computer messing up can someone help me thanks.
Old Jan 18, 2010 | 05:20 PM
capnfred's Avatar
capnfred
did the ce light come on
Old Jan 20, 2010 | 04:47 PM
bbb17's Avatar
bbb17
not that I know of I took it to a shop and they cant find out whats wrong and I dont want to pay them to take it some where else
Old Jan 20, 2010 | 06:33 PM
GEORGE_JET's Avatar
GEORGE_JET
take it to auto zone, (or other parts store) and ask them to check for codes. The ECM will store codes for a finite period so even if the light is not on there may be a code stored. I do not know exactly how long, but if there is a code, can use this as a possible clue on how to proceed.
Old Jan 20, 2010 | 09:21 PM
mmlex1987's Avatar
mmlex1987
Stole your catalytic converter? Where was the vechicle when this happened? I would follow george jets recommendation and have the code checked out.
Old Jan 21, 2010 | 09:24 AM
bbb17's Avatar
bbb17
thanks I'll have her do that and she had her car at a transmission shop when this happened. A friend of mine said that she might have a problem with her computer because it won't stay on.
Old Jan 21, 2010 | 10:06 AM
GEORGE_JET's Avatar
GEORGE_JET
It is "possible" that there is a problem with the computer or any other number of things. Until some tests are done it is just speculation. It could just as easily be something much cheaper than the ECM.
Old Jan 24, 2010 | 05:29 PM
DEEMEHTA's Avatar
DEEMEHTA
Starting problem for my Lexus 1996 ES300:
I drive a couple of miles and I lose power and then I pull over to the side and after a few tries it starts again. This has happened a few times but it always starts after a few times cranking. Last few days when it stops it will not start. It will crank but will not start so I have it towed to a local repair shop and surprisingly it starts at the garage so the mechanic does not exactly know what could be going wrong. So far this has happened three times and it is really frustrating. I have just put in new fuel pump, timing chain, plugs and wires. I have been reading about a similar problem thread posted by bbb17 Would appreciate if someone can offr their expert suggestion/advice - thank you in advance!
Old Jan 24, 2010 | 07:59 PM
llcoolpass's Avatar
llcoolpass
" starting problem"
At least you dont have a going problem!!! HAHAHAHA drug commercials getting into my head.........
get is fully diagnosed using the machine that tests for starting, charging and battery condition -- its free at autozone and advance auto parts, and other companies
Old Feb 1, 2010 | 07:35 PM
bbb17's Avatar
bbb17
we found out that her computer went out
anil1225
Sep 7, 2018 06:32 PM
Enigmatic1
Aug 21, 2018 04:58 AM
foxielexie
Mar 11, 2014 08:44 PM
mervinjule
Apr 7, 2009 01:15 PM
uallah
Apr 11, 2005 09:39 AM
