day time running light
Old Jul 29, 2009 | 11:00 PM
VIP-NOT's Avatar
VIP-NOT
Originally Posted by Kansas
Did you read the thread I pointed you to? --> https://www.clublexus.com/forums/ls4...-in-ucf20.html
If your ES has a DRL relay like the 2000 LS does, you could add a switch at the same wire qewani1 reconnected to get his DRL working again. If I was going to do something like this, I might drill a hole in a panel under the dash and install a very small "push on / push off" switch where it couldn't be seen. I've installed a number of similar switches in cars over the past 40+ years while installing front and rear foglights and all sorts of other wacky accessories.
oops never thought of that , thanks kansas
im gonna go check if my relay is the same as the ls
Originally Posted by Lexucan
Ok, I gotta know....which spy agency are you working for??
im working for the stokers anonymous agency j/k
codenko
Sep 14, 2011 02:02 PM
ViPeRs103
Sep 10, 2010 05:21 PM
dahozy
Apr 17, 2009 10:30 PM
Jay1977
Lighting
Jun 3, 2006 05:04 PM
Lexs400
Mar 25, 2005 03:50 PM
