97 ES strut bar
Old Jul 20, 2009 | 01:25 PM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Default 97 ES strut bar
I've searched and searched and could not find a definite answer on the right bar to get. Another member had to cut his hood for the TRD which I'm not doing..
So, with that being said will the Solara 97-01 bar fit? I found a after market one on ebay for dirt cheap.. Just wanted to add a little something..
Thanks in advanced..
I know Hyperboy has one and i'm sure a few others..
Old Jul 20, 2009 | 04:49 PM
kaldES98's Avatar
kaldES98
I thought that ebay one only fits 4 cylinder camrys? The 97-01 will fit but you have to bend it a little for a hood clearance
Old Jul 20, 2009 | 11:56 PM
tmf2004's Avatar
tmf2004
Thanks.. I may try it.. its only like 10 bucks plus shipping..
Old Jul 21, 2009 | 01:37 AM
Jewel707's Avatar
Jewel707
I may look for one. I wonder how much improvement you will get, let me know.
Old Jul 27, 2009 | 02:30 PM
jasn's Avatar
jasn
post a pic when u put it on.
Old Jul 30, 2009 | 07:00 AM
BoostedE21's Avatar
BoostedE21
I would expect little to none. The first barrier you'd have to cross is better (preferably polyurethane) bushings, better shocks, and springs that aren't oversprung and under damped - or in the case of the stock ones, overdamped and undersprung. Then, wider than stock wheels/tires (185's are way too thin for a car this big). After all of that, you could expect to actually get some legitimate results from a strut bar. Before that, you've just got too much suspension wobble and travel to do much good.
Old Jul 30, 2009 | 07:29 AM
Slooooooow's Avatar
Slooooooow
Regional Officer - NTL
Thumbs up
^^^^^ This!
Add to that, a simple steel (or similar) bar hanging betwixt the upper strut mounts doth not a strut brace make. The construction of the bar needs to be in such a way that you can introduce tension, or bracing between the struts. A majority of the time that means it needs to be constructed ...."solidly" is a pretty good adjective but maybe not emphatic enough. It's also a good idea for it to be adjustable, to help introduce the tension/bracing, since all cars of the same make/model are not exactly alike, dependent on age, wear, tear, manufacturing tolerances, etc.
In other words, when you get this thing in the mail, if you're able to simply remove 3 nuts on each side, drop it in and tighten the nuts back down, there's a strong probability you've done nothing but introduce extra weight to your car.
I could go on...but the above post gave you a GREAT place to start if you haven't already.
Old Jul 31, 2009 | 09:37 AM
Maxx941's Avatar
Maxx941
I had the solara strut bar awhile back, very little improvement if any, and it did bulge my hood abit, just a little to tall in my case, but I heard others had sucess without this problem. I didn't try to bend it at all
Old Jul 31, 2009 | 09:53 AM
BoostedE21's Avatar
BoostedE21
Trouble is, if you bend it, or cut it and re-weld it, you've compromised the strength of the material, and you'll see even less results than before.
tomstep2
Jul 6, 2009 09:29 AM
TruPlaya26
23
May 21, 2007 02:49 PM
golffnutt
Jun 6, 2005 08:57 AM
Lexbox
Jun 13, 2002 07:57 AM
