2004 ES330 Headlight Options?
Hello, I'm a new owner of a 2004 ES330 and this is my first post here on this forum.
I really want to replace my stock halogens headlights and I have two questions:
1. What bulb, can I replace my stock '04 yellow halogen corner parking headlight with, is there an LED that will fit?
2. The 2004 headlights looks to be the same shape as the 05-06 headlights with the projectors. Can I swap these out, or is there mounting modifications required?
Sorry, I tried searching and already read the FAQ but I could not find what I am looking for.
Thanks
Thanks
Can this HID wiring be spliced, has anyone done this? I would think that someone would have done this swap by now. Too bad I cannot find a write up about connecting 05-06 es330 headlights into an 04.
Thanks
Thanks
I'm glad that your an ASE tech. Could you be so kind to recommend the setup I need, in your professional opinion.
To replace my halogen 04 headlights, with the projector 05-06 headlights, what would I need?
Is that correct?
Thanks
- 2x 05-06 headlights
- 2x HID Ballasts
- 2x HID Bulbs (D2C? or DSC? or D2R?)
Is that correct?
Thanks
Its best recommended to go with the original equipment, the 05-06 HID projector lights, the toyota/koito ballasts, and Phillips D2S bulbs. Then you will need to replace the low beam wire connector to plug into the ballasts. You can find headlights complete with ballasts on ebay. Then you should be able to purchase the connectors from lexus to splice into the original low beam harness.
Is this what you had in mind? (scroll to bottom of 1st page)
https://www.clublexus.com/forums/es3...330-xenon.html
I have been wanting to change mine for years, but after spending well over a $1,000 on retrofitting headlights into my Accord; I just can't bring myself to spend that much $$ on headlights again.
R6Tuan
Jan 26, 2016 05:59 AM
HERBos
30
Sep 17, 2009 03:57 PM
