Remove radio cluster
Old Apr 22, 2009 | 05:59 AM
mmatheny's Avatar
mmatheny
Default Remove radio cluster
Is there a how-to to get the radio cluster out? I need to replace the button bulbs in the climate control area. I mean, here's the FSM on it! Real detailed there!
REMOVAL
1. REMOVE THESE PARTS:
(a) End cluster finish panel
(b) Center cluster finish panel
Old Apr 22, 2009 | 06:35 AM
Avidstarr's Avatar
Avidstarr
i think this is what you need
https://www.clublexus.com/forums/es3...radio-lcd.html
Old Apr 22, 2009 | 07:13 AM
mmatheny's Avatar
mmatheny
Thans - I believe that will prevent me breaking other stuff to fix something else!!
Old Apr 22, 2009 | 09:06 AM
basketthis's Avatar
basketthis
Please not that that removal write-up is not for an es300.
To remove the vents on the es300 is a little more difficult. You have to look into the either of the outside vents. Look down into them and you will see a metal clip. This clip must be pried up before removing the retaining side that it is on. You will need to do this on both sides of the top vents. Be careful as this is when the vent piece is broken. Take your time and get one side out at a time and have patience. Good luck.
Old Apr 22, 2009 | 09:56 AM
mmatheny's Avatar
mmatheny
Is the rest of the removal correct?
Old Apr 22, 2009 | 10:51 AM
BadViper22's Avatar
BadViper22
The metal tabs in the middle vents are an absolute pain in the ****. You're going to need a few flathead screwdrivers and maybe even an extra set of hands. Good luck and take your time, things really like to break. And when putting it back in just leave em out so you never have to deal with it again.
Old Apr 22, 2009 | 03:56 PM
Parker Gen's Avatar
Parker Gen
You don't even need to take the vents out to get to the centre dash. Just pull the AC out and then bend downwards slightly to get to the two screws behind it. It won't break, I've done this 3 times now the same way. Just needs a bit of force.
Old Apr 23, 2009 | 07:44 AM
mmatheny's Avatar
mmatheny
Pull the AC WHAT out - vent? Remember this is an '01.
Old Apr 23, 2009 | 08:00 AM
mmatheny's Avatar
mmatheny
For anyone else - just found this tidbit:
http://us.lexusownersclub.com/forums...e=post&id=5671
BTW - no note about metal clips in the AC duct, unless that's the two on top and two on bottom that are pictured.
amals430
Nov 29, 2023 04:55 AM
lbcgav
Jan 19, 2019 07:28 PM
67vettefan
Jan 9, 2018 01:13 PM
froboy272
Jun 30, 2011 06:44 PM
ISguy
IS - 1st Gen (2001-2005)
Jun 10, 2006 05:11 PM
