es300 headlights 2000
whats up cl i have to car and one of the is a 2000 es300 non hid hl i am curious if anyone know if the 92-96 projector headlights will fit in a 97-00 body if so let me know i am about to buy the jdm toyota windom headlight set and see if it will work. if anyone has any knowledge of this being attempted please inform me thanks again!
NO! they may appear the same but they are far from 'similar' or even close to matching the shape & size.
If it were to fit i would have had a set a long long time ago!
Any reason you want projectors? If you want them for show, well dont wastet the money. If you want them for function to run a 'true/optimal' HID light output set than, get someone to 'retrofit' a set of projectors for you.
Smitty, on here had it done on his old headlights, he used Acura TSX projectors since they are optimal/best for light output/cutoff!
-mike
-mike
more or less i wanted them for function due to me regular headlight assembly is very dull and worn! instead of just clearing those i would rather do a full upgrade/ headlight overhaul!
You gotta wetsand them if they are dull and then properly buff them with a polishing paste and will look better than new, if done right. If you have no idea how to do it, nor have the materials to do that, than go to a detailer since you can melt thru the lenses if done imporperly.
EPayne42
Dec 29, 2014 08:54 AM
sirks
Mar 7, 2011 05:36 PM
