'93 Blinker problem
Old Dec 2, 2008 | 11:33 PM
kook's Avatar
kook
Default '93 Blinker problem
I got a problem with my front right blinker, it doesnt blink. Instead the tail blinker and the dash indicator blink @ 2x speed. I thought the bulb was toast but it still lights up with the regular operation (when I turn on the headlights).
About two days earlier I opened up (baked) the headlight for cleaning and sealed it good, the blinker was all good. But today when I was cleaning my car I saw that it was jacked up. The last thing I did before I noticed the whack blinker was I clicked the blinker lever to the right (accidentally tapped it while cleaning the steering wheel column), then as I was about done turned the car on and noticed that the blinker was on. So I turned it off and clicked it back to the right and thats when I noticed it was operating twice as fast.
Any ideas
since the bulb itself lights up on normal operation perhaps its a switch or fuse?
Old Dec 2, 2008 | 11:53 PM
tuan92129's Avatar
tuan92129
Have you replaced the bulb?
The bulb, although it still works may be about to burn out, and will cause the hyper-flashing.
Try and replace them, and see if it fixes the problem or not.
Old Dec 3, 2008 | 12:18 AM
kook's Avatar
kook
I will try this tomorrow and update.
btw I took out the amber and chrome inserts looks pretty good with that raw look.
Old Dec 3, 2008 | 08:18 AM
CUMan's Avatar
CUMan
Remove the right front bulb holder from the headlight assembly. Clean the perimeter of the bulb holder where it contacts the car body. There should be three small bumps where the contact is made. These must be clear of corrosion.
There are numerous threads on this problem. It is a very common problem with the mid-90's ES models. The connection mentioned above is not sealed and is prone to corrosion.
Old Dec 5, 2008 | 02:21 PM
kook's Avatar
kook
bulb was fine, it was the tab in the harness socket that I had to lift a little, works good now thanks.
ecko1211
Sep 3, 2013 10:53 AM
Got F?
IS F (2008-2014)
Feb 7, 2013 07:27 AM
1quikGS
GS - 1st Gen (1993-1997)
Jul 13, 2009 12:50 PM
nordoyan
Jun 10, 2009 06:38 PM
VitB6
Mar 16, 2008 07:59 PM
