2000 odometer question
Old Apr 28, 2008 | 05:51 PM
tmill's Avatar
tmill
Default 2000 odometer question
Looking at a 2000 ES to purchase. The owner says he had to have odometer/cluster replaced. Says the ECU stores the mileage so what is reflected on the new cluster are true miles. Anyone know if this is correct?
Thanks
Old Apr 29, 2008 | 12:25 AM
tuan92129's Avatar
tuan92129
I'm thinking no...because when you go to the dealer to replace the odometer, they put a sticker on your car with the actual mileage, and contact the DMV.
Old Apr 29, 2008 | 07:04 AM
sonyman's Avatar
sonyman
That's not a general rule. When the dealership replaces your cluster, there are two options for the customer:
Option A) Replace the cluster at the cost of the part + labor and put a sticker in the car indicating the mileage at replacement.
Option B) The customer pays a programming fee, and the new cluster is sent to Denso for the correct mileage to be programmed.
If he has the receipt for the service, you should be able to tell instantly. However, you should also be able to tell if you look at other receipts and the mileage at each service.
Rory
IS - 1st Gen (2001-2005)
15
Nov 9, 2010 09:49 PM
ronricorum
Jan 20, 2010 02:42 AM
tonydt1g3r
Dec 8, 2005 08:43 AM
prjctSC300
Feb 10, 2005 08:53 PM
Baby Lex
Mar 23, 2003 09:30 PM
