no compression
Old Dec 16, 2007 | 11:36 AM
Mr.Pink86's Avatar
Mr.Pink86
Default no compression
I had a local shop install my new engine, when he finally got done after like a month and a half he said that the motor he installed had no compression. He said that since he didn't do a compression test he'd rebuild the motor for $750. What do you think could be the problem? do you think that he may be lying or is this a good deal???
Old Dec 16, 2007 | 05:37 PM
esucaris1's Avatar
esucaris1
When you say new engine do you mean new as in rebuilt or maybe what you really mean is a used engine... Did the shop supply your engine or did you? If the shop said they would find you a good used engine and they installed it they should be responsible... If you supplied the engine for the shop to install you should start hearing violins about now... A rebuild for $750 is dirt cheap as in it can't be done... More like $1600 and up for a rebuild... He is probably going to pull the heads and do a valve job for $750 that would be a deal if you supplied the engine...
Old Dec 16, 2007 | 07:29 PM
powerwave's Avatar
powerwave
month and a half?!?!? geez. if it took that long to install a built one, how long is it gonna take to rebuild?!
if he means he's giving you a break for not testing the motor he found for your car, that's on him. he should be taking full liability here.
Old Dec 20, 2007 | 03:15 AM
Mr.Pink86's Avatar
Mr.Pink86
The motor was found by him but bought by me, I had to do it by phone because I'm in the army and I won't be home for a couple of months, but I bought it from ebay from a place called japanese engines inc. Don't know if anyone has heard of them
Old Dec 20, 2007 | 08:11 AM
JSM1284's Avatar
JSM1284
I thought they pressure tested all engines and guaranteed them. I think this mechanic has a broken compression guage, giving you the run around, or the timing belt is broken.
Old Dec 20, 2007 | 08:33 AM
Slooooooow's Avatar
Slooooooow
Regional Officer - NTL
Thumbs up
Originally Posted by Mr.Pink86
...I'm in the army and I won't be home for a couple of months...
kizmazz
RX - 1st Gen (1999-2003)
May 6, 2019 09:38 PM
Rontrell
May 9, 2014 06:17 PM
TofuMaster
Nov 26, 2012 10:01 PM
TecnoSmurf
Oct 16, 2007 07:19 PM
