OBD1 Check Engine Light Codes
Old Apr 20, 2015 | 01:06 AM
  #46
ES300NZ's Avatar
ES300NZ
Originally Posted by pappysc400
My 1993 SC400 is celing code 17 or 71 as it's flasshes all come in continuous stream? can one of my new friends tell me the meaning of these two? 17 or 71. I am jumpered from TE1 to E1with the sophisticated pliable current conducting "paperclip" again i get 17 or a 71 totally different codes. A complete list would be to much to hope for?
http://www.troublecodes.net/toyota/
17 - not listed, engine would probably not be running if that code came up, low numbers are critical codes.
71 EGR System.
Old Apr 20, 2015 | 02:22 AM
  #47
pappysc400's Avatar
pappysc400
Default Is it 17 or 71?
I had copied the codes for OBD1 on a word doc. And I had thought that this would end up being the EGR! Thanks for brain storming for me, and good luck pulling wrenches. You made me think back, "The check light does not begin to flash until the key is turned on. I will pay closer attention and run the test again and see for sure if the 1 comes up before the 7 or if it could be vise versa, and thus the EGR.
Thanks again.
Old Apr 30, 2015 | 04:08 PM
  #48
ichihollow's Avatar
ichihollow
I drew the short straw 52 AND 55... I'm going to try actually properly mounting my PCM since I bought the car early 2014 its just floated under the glove box.
Old May 31, 2016 | 09:21 PM
  #49
eraceyfase's Avatar
eraceyfase
Are knock sensors even relevant in a stock Lexus? Mine has never knocked and I don't need a cel to tell me it's knocking.
Old May 31, 2016 | 11:37 PM
  #50
WILLYumD's Avatar
WILLYumD
Bump rank: Legendary.
Old Jun 9, 2016 | 07:13 AM
  #51
eraceyfase's Avatar
eraceyfase
I was getting the bank 1 random misfire code, IAC circuit fault, and MAF circuit fault, hard starts and bad gas mileage. This all stemmed from changing the air cleaner filter. Ipart of the problem was starting the car right after while the MAF was accidentally left unplugged and the other more serious issue was a tear in the air cleaner duct. I just swapped it for a piece of pipe and it's back to its former glory. It's worth mentioning I have a lot of blow-by but that's what you get on a cat this neglected
Old Aug 13, 2016 | 09:33 AM
  #52
MrMeeseeks's Avatar
MrMeeseeks
I'm bumping this thread again because it has some awesome information that I desperately needed! I've only always had OBD II cars so this is a whole new experience for me, haha.
Thank you!!
Old Nov 4, 2016 | 01:09 PM
  #53
AnTCamCarr's Avatar
AnTCamCarr
Default Please Help Fellow Sc Brothas
Ive got code 71_on my sc400 _ I've seafoamed, cleaned egr and changed sparkplugs, also new cats. Still is bogging/ hesitating to go. In park I can rev and sounds beautiful, once in drive , at 1500 rpm you feel a hesitation , drives fine just runs honestly like **** in my ears ( feels like it wants to go but sounds like its having a hard time ) , I have two 400s and know the beauty sound of the 1u , i want my car running the way it ousto, prior to the work i did the car sat for about two months ( warmed up every week). Daily driven for a year before it sat ,honestly im at a stand right now , cant figure out what part of the egr could be wrong.Dont have much time just need my car running good.thanks!any help appreciated.
Old Nov 5, 2016 | 07:50 PM
  #54
KOEHLERKER's Avatar
KOEHLERKER
Okay guys - did the jumper thing and I get the engine light flashing all the time - no pauses. Would a guy want to just check the connections to the ECU or just pony up and get a new ECU. Car is not running right now as I replaced the fuel injectors and have had two more sent as replacements and they both leaked badly. So waiting on another replacement so I can hopefully get the car turned around so I can get to the passenger side. Damned one car garages!
Old Sep 21, 2017 | 09:49 PM
  #55
92sciowa's Avatar
92sciowa
Default Please help transmission not shifting right RPMs are at 4000 RPMs at 50 miles an hour
Have a 1992 Lexus SC300 approximately a hundred seventy thousand miles on it replace transmission shift solenoids to shift solenoids and one lock up still not shifting into overdrive feels like I have 1st gear 2nd gear and like a low 3rd if that makes any sense like it just won't shift higher almost feels like the car is in limp mode but I was told by Lexus of Omaha at 92 does not have limp mode so does this car have a actuator shift solenoid I thought I seen 5 solenoids when we did the shift solenoids and lock up the overdrive off light went out but the problem still persists please help I'm kind of at a loss already rebuilt the ECU and did not to drain and fills and it's card does not slip I have reverse 1st 2nd and it'll shift to 3rd but I just really sluggish so I don't know if I should just test the ignition coils and everything else I need some pointers please I hate to say it but I'm getting desperate
Old Sep 29, 2017 | 06:44 AM
  #56
92sciowa's Avatar
92sciowa
Default Trouble code 42
So they transmission shop in Omaha they got trouble code 42 which is the vehicle speed sensor so and I have problems with it not shifting into higher gear so do I need a vehicle speed sensor or is it the one that has the two wires going out of it for the automatic transmission so I'm kind of confused on what I should do here
Old Oct 20, 2017 | 08:32 PM
  #57
92sciowa's Avatar
92sciowa
Default Cruise control ECU issues problems questions
So I've had this issue for about 3 or 4 months to where I don't have 4th gear and then I replace the solenoid filter all that stuff did to drain and fills and then driving home the other day I pulled the cruise control over towards me and 4th gear will kick in only when that lever is pulled towards me so is it the actuator or the cruise control ECU which I only can find you two so I don't know where to send that box in to get rebuilt can somebody help me out please 1992 Lexus SC300 thank you felt like I hit the lottery if I pull that lever forward I get I get 4th gear need some help thank you
Old Jun 3, 2018 | 04:16 PM
  #58
Stanley93's Avatar
Stanley93
Good day all! So one day my oil cap magically disappeared.. Idk if its some douche prank but whatever. result: Code 21, 25 and 41.
Going to be searching for those next few days here!
Any help would be absolutely fantastic as im pretty new to mechanics!
geoprz
19
Oct 29, 2022 11:49 AM
aceboogie6
GS - 1st Gen (1993-1997)
Feb 13, 2011 10:28 PM
diverchris
Dec 27, 2010 07:43 PM
breakb
CL of Hawaii
Mar 19, 2009 11:11 PM
ursrob
Mar 24, 2003 08:24 PM
