Fitment
Old Dec 9, 2007 | 07:22 PM
palex's Avatar
palex
Default Fitment
I was wondering if wheels from a 06 IS250 will fit my 97 ES 300?
The wheels have the same bolt pattern, but different offset 45mm, and are 17"x8" wide. If so, will 225/45/17 fit without any rubbing issues? Please advise.
Old Dec 9, 2007 | 11:13 PM
Eyemfaster's Avatar
Eyemfaster
Those will fit fine.
My Moda R6's are 17x8 with a +35mm offset (10mm further out) and I want to say my tires are 245/45/17's. The only problem i have is at full rear compression, my tires barely rub the inside of the rear fender, which shouldn't be a problem for you at all. Post pics after you get them on there.
Old Dec 10, 2007 | 05:33 AM
Choas's Avatar
Choas
CL Folding 10,000
The Is250 rims fit fine Is350 rims are a pita to do but not impossible. You should go on 1010tires.com to figure out what size tire to do cuz I'm almost positive you would want to go with 225/50/17's so your speedo is more accurate.
pg22
Apr 23, 2017 07:40 PM
shui3000
Sep 29, 2011 03:46 PM
mctuners
Feb 12, 2007 11:54 AM
mctuners
Nov 29, 2006 08:14 PM
eddied106
Apr 27, 2003 12:11 AM
