Checking Engine Codes on OBD1
Old Nov 26, 2007 | 06:47 PM
thomyb's Avatar
thomyb
Default Checking Engine Codes on OBD1
Hi everyone! I searched but can't find the answer. How do you check the codes on a 1992 Lexus ES300? So far, I got this:
"To find out the problem source of the Check Engine Light:
Make your the engine is at operating temperature & shut it off.
Get a jumper wire, and at the diagnosis modeul (engine compartment, near the drivers side strut) Connect the "E1" & "T" terminals.
Turn the ignition to "On", do not start. The engine light will blink a code.
Tell me that code, and I'll tell you what to look for."
Is that correct? Also, where do I find a list of the what the codes mean once I get it from the ECU? Thanks!
Old Nov 26, 2007 | 07:00 PM
thomyb's Avatar
thomyb
Nevermind.... found it.
mtyink
Jul 4, 2011 10:18 PM
Niko1981
Mar 7, 2008 07:07 PM
moshlub
Jul 2, 2005 09:37 AM
