How do you program a replacement key for a 1999 ES300?
Old Jan 2, 2011 | 07:59 PM
sphillips's Avatar
sphillips
Found this in another thread. Dont know if it works:
Key Programming
1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3.. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your key is programmed. To end programming step on brake one time.
NOTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
If you perform this procedure too slowly your car will not go into programming mode. If you can not get your car to go into programming mode make sure you are using a master key and not a valet key. If you have a master key then you will probably need to perform this procedure more quickly.
Remote Programming
1. Close and lock all doors. Unlock and open drivers door.
2. Put key into ignition and remove TWO TIMES.
3. Close and open the drivers door TWO TIMES.
4. Put key into the ignition and remove.
5. Close and open the drivers door two times.
6. Put key into the ignition. Close the drivers door.
7. Turn ignition ON then OFF ONE TIME- this will put the car in ADD mode for your remote. (Turning the ignition ON then OFF TWO TIMES will ADD the remote but will erase all existing remotes.)
8. Remove the key from the ignition. The door locks will cycle one time (or two if you are erasing) . On the REMOTE press and hold the LOCK and the UNLOCK button for 2 seconds. On the REMOTE press the LOCK button for one second.
AT THIS POINT, the locks should cycle by themselves ONE time. This means the procedure was accepted. IF the locks cycle twice it has failed. IF this happens you must start over. Hold the remotes higher up for better reception
9. Open and close the drivers door. Put key in ignition and pull out. This will end
programming.
Old Dec 13, 2013 | 11:03 AM
Clintbo's Avatar
Clintbo
Just tried the chip program oN my 2000 es300. Worked perfect the first time. I also did it using the valet key, and not the master. I'm really confused about these folks that are having great and affordable experiences at their Lexus dealerships, mine was rude, and told me to make sure I don't get a key off the internet or ebay.
Well..... Being the risk taker that I am, I bought 2 blanks with remotes on the key off of ebay for $39 for the set. I had one valet key before now I have 2 keys and 2 remotes. I called a local locksmith to cut them for me. My dealer told me they wouldn't cut them, and that I probably wouldn't find a locksmith in Georgia that would cut those for me.
missikg75
Nov 17, 2017 11:30 AM
blah44
Maintenance
Nov 30, 2013 09:46 PM
clubowner
IS - 1st Gen (2001-2005)
Dec 10, 2012 11:19 PM
tmcd23
May 2, 2011 08:41 PM
rumoreno
May 30, 2009 07:24 PM
