Tranny flash
It took a little less than an hour from the time I left the car, til I left with it.
Fine, they want you to demonstrate that you have the "flare"?
Just film it on a camcorder, showing your instrument cluster.
When you combine the sound, with images of the tach jumping up several hundred RPM while the speedometer doesn't when the car shifts, plus seeing the odometer reading being very close, they can't deny it.
Also, what I did, was to create an mpeg file of my car, and when I left a copy of it with them on a CD ROM, I also "helpfully" let them know that if anybody at Toyota wanted to see a demonstration of my "flare", they could go to a link I provided them on Internet, where Up uploaded this mpeg demonstration file.
Example:
http://www.ori.net/edporch/U660Eflare1.wmv
It's a simple ECU flash for a known problem, and they get reimbursed for the time. They are probably avoiding performing the service because it means acknowledging the problem to begin with, which commits them to repairing it if the flash doesn't work.
