Keep Getting Air Bubbles
Old Aug 10, 2007 | 10:11 AM
thedelman's Avatar
thedelman
Default Keep Getting Air Bubbles
I installed new front calipers and pads on a 1998 Lexus ES300. I keep getting plenty of air bubbles when I bleed the brakes. I am keeping the master cylinder filled, so I'm not sure where all of this air is coming from. The pedal keeps going to the floor. The booster is Ok. I'm thinking bad master cylinder. Ideas????.
thanks
Old Aug 10, 2007 | 10:59 AM
kphu's Avatar
kphu
How are you bleeding the brakes?
Old Aug 10, 2007 | 11:25 AM
esucaris1's Avatar
esucaris1
If the master was dry after replacing the calipers you should pre bleed the master... with the lines off have sombody SLOWLY push the pedal down then BEFORE they let up hold your fingers over the holes where the lines go and let up on the pedal... repeat this until no air comes out of the master... make sure you have rags and make sure your helper pushes the pedal SLOWLY
Old Aug 10, 2007 | 01:12 PM
thedelman's Avatar
thedelman
Thanks for the reply.
I didn't change the master cylinder so I kept it full and continued to fill while I was bleeding.
I am having the helping push the pedal all the way and hold, then open the bleed screw and close it when all the air escapes, release the pedal. Repeat that step as often as air comes out, but even after a constant flow of fluid, on the next pump, more air.
Old Aug 10, 2007 | 02:06 PM
esucaris1's Avatar
esucaris1
before you bleed you should rapidly pump brakes about 6 times then hold the pedal down then bleed and repeat until bubbles stop
Old Aug 10, 2007 | 02:21 PM
kphu's Avatar
kphu
The other thing to note is that you should always bleed the caliper that is farthest away from the master cylinder first then go to next furthest one.
Old Aug 10, 2007 | 06:25 PM
92ES5sp's Avatar
92ES5sp
Smile
Exactly. One other thing to note, if you dont clamp off the line somehow before you remove it from the caliper, the lines will be air-bound like a ***** and will take forever to bleed out
toy4life86
Suspension and Brakes
14
Sep 3, 2010 05:14 PM
Sup2jzgte
May 3, 2010 07:43 PM
Sup2jzgte
Jun 5, 2008 11:52 PM
Lexs400
Maintenance
Oct 3, 2005 07:53 AM
sherwood
Nov 29, 2003 07:35 AM
