WT.. Engine oil solid
Old Aug 8, 2007 | 07:25 AM
missdee212's Avatar
missdee212
Default WT.. Engine oil solid
My day cannot be any worst today, I don't know why, but I went and put my finger in the in the engine where you pour the oil and why in the heck is it a solid form. It's like steel hard. Well what made me check that was because the tow truck guy that AAA hired went towing my car other than where he was supposed to and ever since then the car would not start. You could hear it trying but it just won't crank. As I said in another post the car over heated and I hadn't driven it I just started it to put it in gear so that they can tow it. What could do that to the oil?
Old Aug 9, 2007 | 06:12 AM
92ES5sp's Avatar
92ES5sp
Smile
Does it not crank or not start? If the engine rotates, its cranking. Do a compression test or leak down test on the engine. What does the oil look like on the dipstick?
Old Aug 9, 2007 | 06:45 AM
rtk7's Avatar
rtk7
u sure its the oil that feels lik steel?? bcuz when u put ur finger ther, ther should be a steel screen to filter the oil u poor in bcuz i thought the same till i looked closer an it was a filter i thought it was sludge nasty oil but it was jus a screen
Old Aug 9, 2007 | 12:08 PM
95gs300's Avatar
95gs300
When was the last time you change your oil? You might want to change it asap. I heard some stories from a friend who worked at jiffy lube of oil getting like that from people not changing their when they are suppose to.
Old Aug 9, 2007 | 10:02 PM
Pheonix's Avatar
Pheonix
Cool
yup
charater count
Hiroshi12
26
Dec 23, 2016 02:59 PM
leftyjohn
Jan 28, 2016 06:01 PM
tea
Aug 18, 2015 10:22 PM
hmkim
Mar 8, 2013 06:02 PM
chris6878
IS F (2008-2014)
45
Nov 1, 2012 06:10 AM
