Back light Warning Light !
Old Dec 20, 2001 | 08:13 PM
CPerez100's Avatar
CPerez100
Question Back light Warning Light !
This light comes out probably one day every month and then turns off. any help??
wwest (CL member) told me "sand the contact "bubbles" on all of the rear bulbs"
If you have exerience problems like this try this.. I will be doing it Saturday......... just in case, any other suggestion?
This is what I'm talking about... here the light is OFF !
Old Dec 20, 2001 | 09:23 PM
Captain Ratman's Avatar
Captain Ratman
Smile Check All Connections
Wwest is probably right on target. The sensor comes on occasionally because there is a bad contact somewhere between the sensor and light bulb. Best to sand BOTH bulb connectors and socket connector with a very fine sandpaper (800 grit would be good). Then check the wiring back as far as you can including the connectors at every step. Once that is done you shouldn't have anymore problems back there. BTW - check the bulbs themselves to see that they are in excellent shape and don't have loose bases or cracks in the glass or ??
Have fun and let us know how you made out!
Scott.
Old Dec 29, 2001 | 12:16 PM
CPerez100's Avatar
CPerez100
THANK YOU GUYS.. SINCE I DID IT THE LIGHT HAVEN'T COME OUT... THANK YOU BOTH
Old Dec 30, 2001 | 11:49 AM
Captain Ratman
Smile Anytime I Can be of Help!
No problem cperez100! Over my years BOTH driving and repairing cars I have seen just about everything! Makes me glad that I have a newer car.........the old 60's cars were easy to fix but after a while they nickel and dime ya to death! Since I have had my lex, I just do a routine oil check, air filter change, pump her up w/gas and I'm off.....no worries! I couldn't say that for my '68 Mustang in its hey day - lol.
Also if any problem comes up with my Lex, or I just simply need advise or have a question, I know the solutions are just a POSTING away !
Scott.
bsunder
23
Oct 28, 2016 03:01 PM
peterbird
Aug 20, 2016 11:30 AM
YYCAristo
Feb 18, 2014 04:02 PM
se_bb2
Jan 22, 2010 07:40 PM
