Hard wired antenna
Old Mar 31, 2007 | 10:45 AM
lovebug62's Avatar
lovebug62
Default Hard wired antenna
Instead of a powered antenna, I would like to use a hard wired antenna. Any suggestions that would fit a ES300 95?
Old Mar 31, 2007 | 11:28 AM
Lexucan's Avatar
Lexucan
Lexucanafer
Your easiest (cheapest) solution might be to just disconnect the wiring harness to the power antenna while the mast is extended. You will still have a working antenna but the mast won't retract any longer. Unless you are looking for something completely different?
Old Mar 31, 2007 | 02:06 PM
GrahamHill's Avatar
GrahamHill
Thanks Lexucan. I might just do that. Right now its on a little button I put under the dash. I rarely listen to the radio so its no huge hassle. It is pretty lame though
Old Mar 31, 2007 | 02:31 PM
Parker Gen's Avatar
Parker Gen
Does that mean you have to leave it extended??
Old Apr 2, 2007 | 05:21 PM
92ES5sp's Avatar
92ES5sp
Cool
No you can manually extend/retract it, it will just take extra force cuz your still engaged w/ the gears, but dont bend it or youre screwed
jasone36
Mar 22, 2025 03:49 PM
friarush
Apr 23, 2015 10:28 AM
illson_2k
May 27, 2003 11:17 PM
