How many miles will a ES330 go?
Old Sep 30, 2019 | 07:45 AM
  #61
netlander's Avatar
netlander
Originally Posted by harrisbaig
curious, did you do all this? are you still driving it?
Yes, still driving my 2003 ES300, it's at 225k now.
Old Feb 15, 2020 | 08:16 AM
  #62
suev1209's Avatar
suev1209
Default Recommendations for parts to replace due to age - even if still working
Hello all, I have had my 2005 ES for a year and it has 56K. It was a one-owner car and checked out great with a mechanic prior to purchase. I love it and have had no problems but am told it has original timing belt so I am looking to replace. I also have some creaking in the rear when backing out of garage. As a single woman with no real car repair knowledge, I am looking for advice. Are there certain parts or maintenance that should be replaced just because they are old (hoses, suspension, belts, etc.)? I don’t want to spend money unnecessarily and am willing to do upkeep but what is most important? Is it wise to put money in a low mileage car in good shape since it’s already 15 years old? Thank you!
Old Feb 15, 2020 | 08:26 AM
  #63
ilkinandr's Avatar
ilkinandr
Timing belt and water pump etc should be replaced in 15 years lol. As for rear it's prob just rubber. Is it cold out where you are at? If so take a hose and spray the rear stabilizer bar where bushings are. If it doesn't creak when you back up just replace the bushings.i wouldn't start replacing things unless it's broken. If you wanna do preventative maintenance I'd change fluids. Oil, brake, coolant, drain fill tranny (not flush), etc.
Old Feb 15, 2020 | 04:55 PM
  #64
suev1209's Avatar
suev1209
Thanks for the advice. I am I Texas - so weather is a bit extreme ..... hot in Summer and occasional cold in winter but no snow/
Old Feb 15, 2020 | 10:34 PM
  #65
Arsenii's Avatar
Arsenii
Hello,
Here is a website with all the service schedules, just type in your mileage and it will show you the next service due. But still, use some common sense and inspect parts before replacing them..
Hope this helps and best of luck!
Old Jun 5, 2020 | 07:00 AM
  #66
midwest330's Avatar
midwest330
I was quite lucky and purchased an 05 ES330 with 72k on it. One elderly owner. Now has 119k. Hoping it will go 250k+
Old Jun 7, 2020 | 07:07 AM
  #67
RLE's Avatar
RLE
I've got 388k on my 98 es300 and she runs fine! I saw one for sale out here in Texas that had 643k on it. (94 es300)
Old Jun 8, 2020 | 04:54 PM
  #68
Paul33570's Avatar
Paul33570
Originally Posted by koreywill
Bought my ES300 about a year ago with 273k and today it has 291,282 and runs great. Just put struts at all 4 corners and just put new p/s fluid in last week. The previous owners had great documentation but as far as I can tell the coolant has not been changed in a while so that's next. I have no qualms about taking this car on any long trip. Smooth, quiet, comfortable, and just a tick under 30 mpg on the highway. Who could ask for anything more?
What struts did you use? I have Monroe quick struts waiting to be installed after I get new tires.
Old Jul 20, 2021 | 12:51 PM
  #69
TruckerI5's Avatar
TruckerI5
165K on my 2005 es330, and it looks almost factory new and drives like a dream, drives like it is less than a year old. I plan on having it well over 300K.
Old Jul 20, 2021 | 12:52 PM
  #70
TruckerI5's Avatar
TruckerI5
Keep up on oil changes and other fluids, use the proper fluids, keep the timing belt changed out every 90K and you will get well over 250K.
Old Jul 20, 2021 | 09:21 PM
  #71
ES300TX's Avatar
ES300TX
Originally Posted by Dinkydow
I am curious, if properly maintained how many miles do you think a ES330 will clock before it is time for the bone yard? Thanks
I don't know. Mine has 200k and I hear a lifter ticking. It has gotten progressively worse over the last 6 months. Mine might be ready.
I'm ready to graduate to an LS
Old Jul 22, 2021 | 04:35 PM
  #72
xjokerz's Avatar
xjokerz
An LS isn't worth quite as much hype as it gets. Nice car, but anyone used to an ES or a Camry will be disappointed with repair and maintenance costs of an LS. Not to mention the worse gas mileage, RWD inconvenience in crappy weather, and premium gas requirement. I don't know if a slightly smoother, slightly quieter ride is worth what I just mentioned but it's your call, obviously.
Old Jul 22, 2021 | 08:53 PM
  #73
Steven54's Avatar
Steven54
10th Gear
Currently I have 215,000 miles on a 2004 ES 330 with original engine, transmission and radiator. Timing belt has been changed twice. It has received good maintenance over its life, mostly by Lexus dealers. My goal is to get it up to 300k, if its transmission holds up.
Old Jul 23, 2021 | 05:30 AM
  #74
koreywill's Avatar
koreywill
RLE has me beat but my 2003 ES300 is about to hit 360,000. Maintenance is the key. Even better when you can do it yourself.
Old Jul 24, 2021 | 04:01 PM
  #75
satiger's Avatar
satiger
Mine is with 354k miles, original owner . Follows the maintenance schedules religiously.
