Strange issues
Old Aug 7, 2006 | 03:18 PM
P_M_G's Avatar
P_M_G
Default Strange issues
Back again....
So I'm jumping out of the lex to grab some 7-11 java this morning (cuz I can't justify $4 for starbucks)...and I hear a strange 'ding ding ding ding' as I'm getting out.
You know the sound, it's the one that usually happens when you open the driver door without taking the keys from the ignition...or maybe it's the one when you turn the key to ACC instead of OFF.
Either way, it only happens when I turn off the ignition, remove the key, then open the door....
2nd...I noticed that the right rear door doesn't seem to have any effect on the illumination of the interior lighting. Meaning, it's dark, and I open the rear right door first, the light doesn't come on. Or if the other doors are open (then closed) and the right rear is the last one still open, the interior light goes out...
3rd...I'm beginning to notice on cold starts that it takes several minutes for my temp gauge to hit the normal spot just a hair below center. During that time, acceleration is abyssmal. What seems odd, is that if I stop for a cuppa joe before it 'warms up' - when I start it up again, it's right where it needs to be almost immediately. Now, realize that I'm in southern California and a 'cold' start just means it's been sitting in my driveway all night and it's the middle of the hottest summer in history here (some nights staying well into the 70's).
4th...and this is just a ***** because I felt stupid - I had new tires put on and did the alignment shortly after I bought this car in '05. I'd driven a total of about 11k miles and never rotated them. I noticed that the fronts had worn down to the steel while the rears looked nearly new. My wife's Accord had the tires rotated even less frequently than that (she is notorious for poor car maintenance habits) and it was never that bad. The tire guy gave me a story about the Lex being significantly heavier and harder on the tires as a V6 vs the Accord's V4. Add to that, my alignment needed adjusting and they had to take 3 tries to get it right - some bs about weight and load with passengers vs empty since the first 2 tries showed spot-on to spec. Is this just a line of BS? Or am I a fool for going to a tire specialist instead of Lex/Toyota to have that work done?
I'd appreciate any/all comments and suggestions on all these issues!
Old Aug 7, 2006 | 03:44 PM
Slooooooow's Avatar
Slooooooow
Regional Officer - NTL
Originally Posted by P_M_G
Back again....
Sunroof open, or tilted? Mine dings to let me know that my sunroof is open/tilted.
Opening, or leaving the rear doors open on my '92 ES do not affect the dome lamp (or any other interior illumination either).
Old Aug 7, 2006 | 04:00 PM
Pheonix's Avatar
Pheonix
Cool
Werd. Sunroof, my rear doors too.
Old Aug 7, 2006 | 08:13 PM
nymviper's Avatar
nymviper
This was my case too.....just look when u open the door on the door body jam....take out the button wit i believe a 7mm socket play wit it till it works...replace
Old Aug 8, 2006 | 04:59 PM
dangtong's Avatar
dangtong
Check your headlights and the switch
Old Aug 21, 2006 | 08:48 AM
P_M_G's Avatar
P_M_G
ok...I win the "de de de" award for the week....it was the sunroof. Somehow I guess I hit the slide switch just enough that it was tripping the sensor.
Old Aug 21, 2006 | 12:44 PM
AzNMpower's Avatar
AzNMpower
1. I don't seem to have the sunroof sensor do I don't have issues with the warning chime. Besides the fact that its the most goddamn annoying chime ever.
2. The door ajar sensor for the rear door might be not working properly. Basically, when you shut the door properly, the switch is pushed down and the car recognizes you've shut the door. When you open the door, the problem is that it still thinks the door is closed, so it doesn't do anything. I attached a photo of what the switch looks like; play around with it since chances are it's not broken.
3. It takes roughly a mile or so of easy driving before my ES warms up to the point where it will shift out of 2nd gear. For it to reach the normal point right under halfway, it takes about 2-3miles. During this time, shifts are quite clunky and presumably accel isn't as good, although I've never dared accel hard with a cold engine. And by the way just because its 90F outside, doesnt mean the engine will stay warm. Engines operate at very high temperatures, and 90F really isn't anything. I just wish Lexus could have found a quicker way to get the drivetrain warm. My bimmer's automatic runs a more aggressive shift pattern to warm the engine up quickly.
4. I rotate the tires every 5k miles when I give it an oil change at the Lexus dealer and ask them to rotate/ balance. If there's excessive wear, check the alignment although it looks like you had it done (?). I run on Yokohama AVS dB S2 and with it's relatively soft treads, the front does wear out quicker since its front drive and there's a weight bias towards the front. I have to rotate vigorously, and the tires are usually shot by 15k miles.
Old Aug 21, 2006 | 02:30 PM
ssmoked's Avatar
ssmoked
1. it definately the sensor for the rear door. mine does the same but only the left one.
2. get a remote engine starter to warn up the engine if you dont wanna wait for the engine to do its business
3. try let some air out to 32psi or so. i rotate my tires every 3000 miles with my oil change and it still weared out the sides much faster. but after the air was let out, magic, less and even wear. oh yeah take the corners easier Earnhardt JR!!
Old Aug 21, 2006 | 07:19 PM
AzNMpower's Avatar
AzNMpower
Haha you talkin to me? I like to corner fast as ***** even though I know the car wasn't designed for it. Corner + throttle = understeer on my ES though
But corners are what my Bimmer X3 is for........handling on that thing in the dry is amazing.
Old Aug 22, 2006 | 03:03 PM
P_M_G's Avatar
P_M_G
thanks to all!!
Astrobear
Mar 14, 2018 05:42 PM
Tmymck
NX - 1st Gen (2015-2021)
Apr 23, 2017 06:49 AM
alvaroe16
Aug 16, 2015 10:14 PM
jag1
RX - 1st Gen (1999-2003)
Aug 28, 2011 08:36 AM
bs0dxi
Jan 7, 2011 10:51 AM
