Oct 2, 2001 | 07:48 PM
Ok i want to drop a nasty system in my '97 Es300 But i need to know how hard it is to use a different amp? Is it a pain in the A$$?I have a McIntosh Mc440 6 channel amp to work with and would like everything to look stock. Can i use the factory stereo?
I need some Suggestions here!!!
Reply 0
Oct 26, 2001 | 11:49 PM
Yes you can use your factory stereo for your amp.. BUT you need to buy a transformer. This transformer will (transform) speaker Output into RCA's. Now.. if your amp has a High Input then you can hook it up there.
Hopefully you will NOT hear the ground noise. If you do let us know.
Carlos
Reply 0
Oct 27, 2001 | 02:09 AM
I just got started on my system for my 92. I had to have a custom panel made for the dash and when you have the factory stereo removed there was an amp under the passenger seat at least in mine. I had everything removed and the new head unit installed and custom dash kit for $120 seemed worth it for me. Took me a month to find someone to do it
alec
Reply 0
Oct 28, 2001 | 05:04 PM
Stereo
In mine I used to factory deck and ran 2 12's and a Kicker amp off of it. All I had to do was buy one of the SLOC ll RCA converter(made by Stinger) and tap it in to the factory rear speakers. Which turns them into sort of a amplifier. Most any stereo shop can do this for you or at least the one near me did and they should have the converter in stock.
Reply 0
Nov 2, 2001 | 06:48 AM
Yeh you could do that but using the factory radio really kills the performance of your speakers. I used to have 2 12" Audiobahns hooked up through the RCA Converter to a 600watt amp, and it was loud, but I then replaced the factory radio with a 2001 Panasonic DQ701U and it was a lot louder! The reason being is that the RCA Converter sends out a measly 1V signal to your amplifier. The Aftermarket radios send anywhere from 3V-6V, making your system a lot louder.
Reply 0
Nov 2, 2001 | 09:14 AM
yea I know but I havent really made up my mind of what kind of deck I want.....and where can I find a dash kit to install a new deck?
Reply 0
Subscribe
