Question about rotors
I'm looking to change my rotors, I've searched online for Brembo blanks. My question is whats the difference between these part #'s :
Front: N1000-182967 vs. BR25358
Rear: N1000-114569 vs. BR25161
From searching for Brembo blanks (2001 ES300), both of these part #'s come up, I just want to make sure I'm ordering the correct rotors. Thanks.
Since nobody responded, I'll just pitch in. Can you pull up the link where you found the Brembo rotors online, and we can go from there? It's hard to explain the part numbers without knowing where the source is from.
Here are 2 sites in which I have found the part #'s.
http://www.buybrakes.com/brembo/am-apps-Lexus.html
-BR25358 & BR25161
http://replacement.speedyperformance...l=null&dp=true
-N1000-182967 & N1000-114569
Thanks for the help.
-BR25358 & BR25161
The difference I see from the links you provided are that the part numbers BR25358 & BR25161 indicate ventilated disc brakes for the front and solid disc brakes for the rear, and the other ones are for Brembo blanks (front and rear). As far as function goes, the brake rotors sold on buybrakes.com are your best bet since they do the kind of braking job expected for a front-wheel drive vehicle. My assumption is that you may not get as much braking performance from the Brembo blanks as expected.
But then again, what do I know, as I have no experience with any of these rotors. Anyway, hope this info helps.
AUbeast86
Suspension and Brakes
Oct 22, 2009 04:59 PM
