Another Headlight Problem 93ES300
Old Mar 15, 2006 | 10:15 PM
FwC's Avatar
FwC
Default Another Headlight Problem 93ES300
I purchased some headlights from ebay for a 1996 ES300. Turns out these are JDM headlights. The Z pattern is higher on the left and lower on the right, I know it is supposed to be vise-versa in the US. My brother said we may be able to change out the heat shield from the older headlights and swap them into the new ones, however is uncertain because he is not familiar with the projector assembly. Is this possible, any ideas?
Old Mar 16, 2006 | 11:58 AM
Pheonix's Avatar
Pheonix
Cool
No it's not.
The best you can do is cut part of the old heat shield out, then weld / jb weld / epoxy a new custom shield in.
Old Mar 16, 2006 | 06:57 PM
FwC's Avatar
FwC
Originally Posted by Pheonix
No it's not.
Sounds like a lot of work Pheonix, I'll take apart the old one's to locate the heat shield. Are you saying I should cut it off the heat shield from both lights and weld on the old ones to the set I want to use?
R6Tuan
Jan 26, 2016 05:59 AM
heyarms
Oct 9, 2011 03:57 PM
Lexus400mn
Automotive Care & Detailing
46
Aug 27, 2007 05:25 AM
omgitsroy
Oct 29, 2006 10:44 PM
mjames08
Nov 1, 2003 10:04 PM
