Acis?
Old Feb 1, 2006 | 12:45 PM
lexusls430's Avatar
lexusls430
Default Acis?
Hey everyone i was reading in some of the old posts that you could mod your acis system, how could you do that? Thanks
Old Feb 1, 2006 | 01:05 PM
Pheonix's Avatar
Pheonix
Cool
Depends on the system, but there are multiple ways. What you want is the ACIS flap to stay shut all the time on all v6's pre vvt-i. (i.e. ACIS-1, and ACIS-2)
Be that re-doing the vacuum connection, making your own trigger for the ACIS flap, or simply perminantly closing the flap itself.
On the newer dual TB & ACIS-3 systems, noone has modified one yet, but I am sure that it, like past ACIS systems, has much room for improvement.
Not because ACIS dosen't work... But because the way it is applied is retareded. Toyota puts much crap in the manifold & air chamber itself - causing massive velocity losses - lowering power across the board compaired to simply not having it in the first place!
Old Feb 1, 2006 | 01:13 PM
lexusls430's Avatar
lexusls430
Ok, closed is the position when it hits the 3500rpm right or is closed when the car is idle or shut off?
Old Feb 1, 2006 | 01:23 PM
Pheonix's Avatar
Pheonix
Cool
That is what happens on ACIS-1 & ACIS-2 systems when the flap is closed all the time, or by 2500rpm. It is a free 500rpm of power, because you don't suffer from power loss as the ACIS system closes around 4100-4200rpm.
What happens on the ACIS-3 system is what I believe would happen with the perfect combination of open/closed valves.
Old Feb 1, 2006 | 01:51 PM
lexusls430's Avatar
lexusls430
O ok, which way is closed, sorry for being dumb. If i open it toward that yellow screw completely and rev it a little bit i hear a weird noise coming from it.
Old Feb 1, 2006 | 04:59 PM
Pheonix's Avatar
Pheonix
Cool
That's closed.
ACIS-I & ACIS-II are like so:
What car are you modifying? What engine?
Old Feb 2, 2006 | 02:51 PM
lexusls430's Avatar
lexusls430
Its a 2000 Solara with the 1mz. The flap like that=closed? To modify it dont i just need to pull that vac line? Or is closed when the vac line sucks the pin and that butterfly is flush with the rest of that piece? Sorry for the confusion.
Old Feb 2, 2006 | 02:54 PM
Pheonix's Avatar
Pheonix
Cool
If you pull the vacuum line, it will be a vacuum leak, and stay open all of the time. The leak will cause problems, and the flap open is the opposite of what you want in the first place.
Does the '00 Solara have the dual tb's, or the single tb like the Camry?
Old Feb 2, 2006 | 03:00 PM
lexusls430's Avatar
lexusls430
Its single tb. Looks just like that. Ok so i want that flap to stay closed so the top of the manifold is seperate than the bottom. Wouldnt i loose low end torque? I thought you want it open for low end and closed for top? thanks
Old Feb 2, 2006 | 03:09 PM
Pheonix's Avatar
Pheonix
Cool
Yes you want it closed all the time. It will provide more power, and more aggressive noise. Like I've said before, without a dyno, it won't feel as fast because it's a smoothe powerbuild, instead of low power, then + 10bhp when it flips.
Like I said
https://www.clublexus.com/forums/sho...19&postcount=4
Old Feb 2, 2006 | 03:33 PM
lexusls430's Avatar
lexusls430
Ok, could i slide the pin back and tie a string so it stays closed? Wouldnt i loose low end tq with it closed all the time?
Old Feb 2, 2006 | 04:06 PM
Pheonix's Avatar
Pheonix
Cool
No you will not. Please don't make me say no again LoL!
Old Feb 2, 2006 | 04:23 PM
lexusls430's Avatar
lexusls430
LOL, then what was the point of this system in the first place?
Old Feb 2, 2006 | 05:46 PM
Pheonix's Avatar
Pheonix
Cool
My theory has always been to lower power production to lower fuel consumption, and to say Toyota has a varriable inake system.
Old Feb 2, 2006 | 06:28 PM
lexusls430's Avatar
lexusls430
Makes sense, im trying to find a solution to the slowness my car at wot from 70-80 and on.
