Wierd problem what do you guys think?
Old Nov 10, 2005 | 07:25 PM
lexusls430's Avatar
lexusls430
Default Wierd problem what do you guys think?
Hey guys i recently got a Toyota Solara V6 no it isnt a lexus but i thought maybe since it has the same engine as the ES you guys could help. When i start the car up in the morning there is absolutely no blue smoke coming out but say if i drive some where and come back and restart the car lets say 3 hours later there is blue smoke for like 5 seconds at start up only. Its wierd because it doesnt happen in the morning. Thanks i appreciate it.
Old Nov 10, 2005 | 10:48 PM
amf1932's Avatar
amf1932
Blue smoke out of the exhaust usually indicates oil that worked it's way into the combustion chamber. This can be caused mainly by bad piston rings, but since it's so slight I would check the PCV valve to see if it's operating properly. Also, how much mileage does the car have, what weight oil are you using, and do you have to add any oil between oil changes?
Old Nov 11, 2005 | 06:37 AM
lexusls430's Avatar
lexusls430
I changed the pcv valve it seems like its working good, it has 101k, im using 10w30 and i dont really have to add any oil. I thought that maybe its the valve stem seals but when i changed my spark plugs they werent really fouled at all. And it never happens in the morning. Thanks
Old Nov 11, 2005 | 06:50 AM
amf1932's Avatar
amf1932
I wouldn't worry about this too much since the car has over 100K miles and otherwise is operating normally. It's probably due to normal wear and tear of the engine. On the other hand, if it was causing fouled spark plugs, then you probably should check the engine clearances to make sure they're in spec.
Old Nov 11, 2005 | 07:24 AM
lexusls430's Avatar
lexusls430
Yeah none of the plugs were fouled, i shouldnt worry but i hate seeing blue smoke
Old Nov 11, 2005 | 08:06 AM
Pheonix's Avatar
Pheonix
Cool
Plugs fouling is pretty sever oil useage. They next to never foul if the rings, or head gasket isn't shot. Don't trust the plugs not being fouled.
You're probably right, valve stem seals.
Old Nov 11, 2005 | 03:52 PM
lexusls430's Avatar
lexusls430
Why doesnt it happen in the morning is a question im asking my self?
Greg5OH
Jan 24, 2014 12:27 PM
yogibeara
RX - 1st Gen (1999-2003)
Jun 29, 2013 06:39 AM
jmezo
Apr 4, 2011 06:00 AM
JDMUSCLE
Jan 3, 2006 02:16 AM
r4z0r3ck
Jul 19, 2002 08:58 AM
