Problem Starting
Old Sep 9, 2005 | 04:56 PM
kentmw01's Avatar
kentmw01
Default Problem Starting
I've got a 94 ES300. I think my battery was dying so I replaced it. Once I installed the new one it still will not start. I've got small amounts of power, the radio and lights work and it almost feels like it is charging??? I'm not sure if anyone else has encountered this problem before. I believe if the alternator was the problem nothing would be working....
anyone have any ideas???
Thanks in advance for any help
Matt Kent
Old Sep 9, 2005 | 06:01 PM
MattB's Avatar
MattB
Does the car turn over like it's trying to start?
Old Sep 9, 2005 | 06:06 PM
kentmw01's Avatar
kentmw01
no, it just ticks, and then it won't even do that (tick) until I let it sit for a little bit.
Old Sep 9, 2005 | 06:10 PM
MattB's Avatar
MattB
Sounds like a bad starter.
Old Sep 9, 2005 | 06:12 PM
kentmw01's Avatar
kentmw01
I had just jumped it the other day and it started...could that happen if the starter was bad?
Old Sep 9, 2005 | 06:18 PM
Pheonix's Avatar
Pheonix
Cool
I think my battery was dying so I replaced it...
1) Clean the terminals, no matter how clean they look.
2) Check that the main relay clicks when the key is turned on.
3) The new battery is dead, get another one.
Old Sep 9, 2005 | 08:07 PM
kentmw01's Avatar
kentmw01
thanks Pheonix,
The terminals apparently weren't clean enough, a little baking soda and warm water cleaned them up and then it started.
Thanks for your help
Old Sep 9, 2005 | 08:45 PM
Pheonix's Avatar
Pheonix
Cool
No problem, glad it's that easy!
Get the felt pads to go under the terminals for like $1 this weekend. Those work the best to keep this from cropping up now that they're clean.
You can also use die-electric grease <cough> vasoline <cough> to try to seal everything, but that will evaporate eventually & it doesn't last as long. :\
Old Sep 10, 2005 | 02:50 PM
koolaidman's Avatar
koolaidman
Matt Kent
the brushes in the amature have gone bad. time for new starter or
if u want u can bring an extention and hammer and tap the starter. this is only a temp fix
damihall
May 25, 2012 06:28 PM
GoTigersGo
May 18, 2011 08:40 AM
Konnan101
Nov 19, 2010 06:59 AM
zombie
RX - 1st Gen (1999-2003)
Aug 24, 2008 12:13 PM
UTGS400
Maintenance
May 12, 2005 06:58 AM
