anyone have this problem before?
Old Sep 21, 2005 | 12:54 AM
OldSkoolGS's Avatar
OldSkoolGS
Originally Posted by Pheonix
If it smokes out the tailpipe, you've blown a headgasket.
Otherwise, Bridge E1 & OP1 in the Diagnostic port & make sure the cooling fan spins to high speed. If not, plug the connector back on the powersteering pump. If so, change the thermostat, coolant pressure caps (both) & radiator. Finish by changing the water pump.
well the fan spins great and the radiator was changed already once i bought the car a couple days ago, and what do you mean by plug the connector BACK on the powersteering pump???
also today while the car was pretty hot. i was stupid and thought the car cooled down to check if it had any coolant left and i open the radiator cap and COOLANT IS EVERYWHERE HOT COOLANT ALL OVER THE ENGINE can this be a problem i ended up just going to the gas station and re filled the coolant but it leaks near the center of the engine i also toped of my power steering fluid and brake fluid yesterday morning.
rafeet
Maintenance
Aug 19, 2014 12:52 PM
bucs1985
Nov 15, 2013 04:04 PM
jshooter55
GS - 1st Gen (1993-1997)
Sep 23, 2012 05:47 PM
o_man_76
Jul 4, 2011 12:08 PM
martini53
May 1, 2003 03:02 PM
