lexus newbie help! trunk will not close
Old Jun 9, 2005 | 04:41 AM
splintercl's Avatar
splintercl
Default lexus newbie help! trunk will not close
ive tried everything.the trunk will not latch shut.the mechanism looks fine.96 lex es300,any solutions
Old Jun 9, 2005 | 04:54 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Try putting the key in the trunk lock and manually unlocking it. I've seen the little catch that locks it get flipped sometime and need to be unlocked before mine will shut (different model though).
Old Jun 9, 2005 | 06:08 AM
splintercl's Avatar
splintercl
i tried that .still no go.the catch seems to latch when i push down on it with a screwdriver.it baffles me
Old Jun 9, 2005 | 08:33 AM
bri67ran's Avatar
bri67ran
I had a similar problem about two months ago with my hood. My Dad told me to oil the hinge assembly with a lubricating oil - but not WD40. I did it and it worked.
Mine was similar because I could get it to engage with a screwdriver too. That helped me know where to oil - hinge points and such. Also, try to get some down the cable for the remote release. This is probably the real problem.
Hopefully you will find the trunk easier to access than the hood, it was a #(%&@.
Good Luck
Old Jun 10, 2005 | 05:00 AM
splintercl's Avatar
splintercl
i took the latch assembly off and greased it up still did not work,but then i noticed part of the plastic gear hooked to a small motor was out of place. i put the latch assembly back in and the trunk closed.i cant use the button on the door now because it throws the gear out and i have pry it back with a screwdriver.i disabled that in the glovebox.i can only use the key to open the trunk,so it will still latch.
do i need a new lock mechanism,so the door button will work again
imaginary1
Nov 6, 2012 09:06 AM
kudos34
May 12, 2012 08:27 AM
hlu1
IS - 1st Gen (2001-2005)
16
Oct 24, 2010 12:27 PM
joe diego
Mar 20, 2008 10:23 PM
fa48
Canada
Jul 16, 2007 11:36 AM
