Excessive (?) condensation/dripping
Old May 9, 2005 | 10:44 AM
P_M_G's Avatar
P_M_G
Default Excessive (?) condensation/dripping
Hey again....
I've noticed lately that my '94 ES has been dripping what seems to me to be an excessive amount of water after parking it. It's a serious drip that forms a good footlong wet spot on my slanted driveway. Drips for several minutes.
I run with the auto climate on all the time.
I know it's not coolant or fluid since no stain on the driveway.
Is this something I should be concerned about?
Recent work done:
new O2 sensor
new water pump
new timing belt
coolant flush
ps flush
trans flush
Thanks!
Old May 9, 2005 | 11:09 AM
bri67ran's Avatar
bri67ran
In almost every case, you will find that this is simply condensate (water), from running your air conditioner. If the fluid is clear, touch it and smell for any strong odor. If none, it is most likely just water.
Old May 9, 2005 | 01:07 PM
steviej's Avatar
steviej
If you run with the auto on, then the climate control system is doing what it is supposed to do.
It is pulling the humidity out of the cabin air, condensing it and allowing it to run off as liquid water.
It must be getting warmer and more humid/moist where you live.
steviej
Old May 9, 2005 | 03:08 PM
P_M_G's Avatar
P_M_G
Yah, I'm in So California....
I figured that's what it was, but it seemed to be an awful lot of moisture so I wanted to be sure!
Thanks for the quick replies all!
triage400
Jul 31, 2018 12:35 PM
RainaES350
12
Jun 1, 2015 11:02 PM
Shervin350
Sep 15, 2012 07:45 AM
kjr11mjr
Dec 14, 2010 06:32 AM
jhuang2668
RX - 1st Gen (1999-2003)
Jun 26, 2010 09:59 PM
